aristo tranny into sc300
Old 07-25-11, 01:34 PM
Tr777
Tr777's Avatar
Default aristo tranny into sc300
Ok guys I bought a tranny from the aristo 2jzgte to put in my na sc300 and realized the outputs on the trannys are not the same, Is it still possible to put the aristo tranny in my car and what do i have to buy?
Old 07-25-11, 02:07 PM
88supramki
88supramki's Avatar
I don't believe the aristo trans will run properly on the SC USDM ECU
Old 07-25-11, 02:12 PM
93MSB
93MSB's Avatar
correct, the aristo transmission's line pressure is controlled by a set of solenoids and the ECU itself
the NA SC300 ECU does not have the capability to control the transmission since the pressure is controlled manually through a cable on the NA transmission itself, the ecu has nothing to do with its line pressure.
why did you go with the aristo trans to begin with? are you looking to make some good power down the road?
if your just looking for a good running transmission you need to find a stock sc300 trans OR one from a NON-TURBO Supra.
if you need one that holds a little more power you can try to get ahold of a soarer auto tranny, it has the extra clutch packs with the manual pressure control. The plug @ the shifter on the transmission are different though, and would need to be swapped
the only easy way to get that aristo trans running on your setup is to go to a standalone ECU, or do a 2jz-gte swap
Old 07-25-11, 09:47 PM
Tr777
Tr777's Avatar
Im planning on doing a 2jzgte swap but did not see the difference till after I got it lol. I didn't spend much on the tranny but I'm gonna go ahead and try to get a motor. I got it because my tranny sounds kinda bad.
Old 10-24-12, 12:56 PM
flexspeed
flexspeed's Avatar
i just found out that aristo trany will not work... but 93MSB mention that it work if use standalone.... which i am running AEM ems
now... my sc is a NA-T and i dont believe the trany cant hold on so i told to use a twin turbo trany... so friend got me a aristo trany..
from reading it and did research.... i did found a information on club NA-T but no longer working.. that is possible of you switch over certain item over to the aristo trany to work... somehow that information is not there anymore....so with the AEM... will i be able to use the aristo trany.... please help me out... thanks
Old 02-08-19, 11:21 AM
vinyvin
vinyvin's Avatar
You do the swap?
weeters
SC- 1st Gen (1992-2000)
12-13-15 12:32 PM
xspsi6
07-19-12 09:56 PM
90supraT
01-04-10 03:56 PM
StimpzSC3
10-22-07 02:17 PM
DETUNED
04-27-06 06:25 AM
Quick Reply: aristo tranny into sc300
