1UZ crank bolt
1UZ crank bolt
The engine is out of the car, on the ground. It's a bare shortblock for the most part and I want to tear it down further. The question is, how do I lock the flywheel to get the damn crank bolt out? Impact gun is worthless so anyone have any ideas?
EDIT...got it out by jamming a Porsche flywheel lock on the flywheel. That bastard is in there tight!
1JZ Single SC400
Go buy you a wrench vise grip. Make sure its at least 9 inches long. Place an old rubber belt around the pully then lock the wrench around it. This will assure it will not damage the thread. Then take a 22mm socket with a long pry bar and turn it while holding the wrench. . It should come loose. Its on their by 192foot pounds.
daihap133
01-06-11 04:15 AM
Blk97SC300
Performance & Maintenance
17
03-29-07 07:00 AM
