1jz swap temp fix doesn't seem to work for me
Old 07-21-11, 05:26 AM
DoomLight
DoomLight's Avatar
does it matter wear i add this resistor? couldn't i added it to the orange body plug down by the passenger side kick panel instead?
Old 07-21-11, 05:56 AM
g-magoo
g-magoo's Avatar
Originally Posted by 88supramki
You wire the resistor inline with the wire correct? Never found the correct description of that.
----RR----
Like that^?
Yes, just cut the wire and add the resistor in line.
I wouldnt think itd matter as long as you make sure the resistor is wired into the wire that provides the signal to the cluster. I just did it close to the plug that attaches to the cluster. It takes all of 5 minutes to take the cluster out and you dont have to get under the dash.
Old 07-22-11, 05:52 AM
DoomLight
DoomLight's Avatar
thanks guys! i will do this as soon as possible. just been so busy to get to radio shack to buy this resistor. i hope i can just buy one. i dont wanna get a whole 10 pack lol
Old 07-22-11, 08:47 AM
88supramki
88supramki's Avatar
a pack shouldn't be too expensive. you're probably looking at a couple dollars
It's $1.19 for a 5 pack...i think you can find that much change under your seats
http://www.radioshack.com/product/in...ductId=2994584
http://www.radioshack.com/product/in...ductId=2062319
Can anyone confirm what wattage is needed?
Old 07-23-11, 05:52 AM
DoomLight
DoomLight's Avatar
thats all? damn. im going to get some now
Old 07-25-11, 08:25 AM
g-magoo
g-magoo's Avatar
Id have to look at the package and see what I bought. Although I only remember radioshack having only one variation of the 330ohm resistor, in the actual store.
Old 07-28-11, 04:56 PM
DoomLight
DoomLight's Avatar
here is an update. ok fellas. who else has any ideas?
i even made a video. i have no exhaust hooked up yet. just open dump.
youtube.com/watch?v=Lyst051_ilM
or full link here
http://www.youtube.com/watch?v=Lyst051_ilM
Old 06-09-13, 02:05 PM
kez
kez's Avatar
Ok so I tried to ground the brown/ black wire and it didn't work so I'm gonna try the resistor method tomorrow and see what's gonna happen
Old 06-09-13, 03:31 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Sorry for your headaches man. Post up your findings after your resistor is added. We will have our fingers crossed.
Old 06-11-13, 10:25 AM
Vrank
Vrank's Avatar
If you guys weren't half assing your swaps this wouldn't be a problem. You wire the 1 wire temp sensor exactly how it is factory and this works. The cluster also has a ground wire that grounds through the engine harness. Leave it in the stock location when wiring since there is no need for this to be removed and it works. Just fine. Like normal. This is really not that hard.
Old 06-11-13, 11:19 AM
kez
kez's Avatar
That's a lot of info vrank thanks
Old 06-11-13, 11:39 AM
99SC42
99SC42's Avatar
This^^^^^
But he might have a broken wire or the wire is not in the correct pin.
Do you still have your stock 2jz harness? if you do just chase the sending unit wire from the connector to the body plug and see if its going in the correct location.
Old 06-11-13, 12:17 PM
kez
kez's Avatar
No I have a soarer 5speed harness Quick. Im going to try and tap into an actually ground wire.
I'm feeling confident the ground to the abs ecu isn't working
Old 06-11-13, 12:27 PM
99SC42
99SC42's Avatar
I know!
Where your stock ge harness? do you still have it?
Old 06-11-13, 12:43 PM
kez
kez's Avatar
It's on the stand still connected to the ol GE
Gonna trace tonight
Quick Reply: 1jz swap temp fix doesn't seem to work for me
