Innovate Wideband Sensor
Old 07-03-11, 08:18 PM
SC51
SC51's Avatar
Default Innovate Wideband Sensor
Ok so like everyone said it would my sensor **** the bed for my Innovate wide-band. So instead of going threw Innovate to get the sensor I read on a site that the Bosh O2 Sensor for a golf gti 1.8L works and plugs rite in.
Can anyone clarify this?
Old 07-03-11, 08:35 PM
SC300_704
SC300_704's Avatar
i believe vw uses the same sensor but not sure which model. there's a part # on this ebay listing i saw recently that you might want to check out http://cgi.ebay.com/ebaymotors/Innov...Q5fAccessories
Old 07-04-11, 08:27 AM
SC51
SC51's Avatar
Thanks SC300_704
I also did some research and found you can use these
for reference, the bosch part number is:
0258007057
Bosch US part number is:
17014
and the VW part number is:
021-906-262-B
it is the stock replacement sensor for the following vehicles:
Oxygen Sensor, Before Catalyst, aka the upstream o2 sensor
Audi
TT 2002-2006
Volkswagen
Beetle, Beetle Turbo S 2002-2004
Eurovan 2001-2003
Golf 2000-2001
Golf GTI 1999-2005
Golf GTI 1.8T 2006
Jetta 2005
Jetta GL 2003
Jetta GLS 1999-2004
Jetta GLX 1999-2002
Jetta Wolfsburg Edition 2001
If you just go to your local Autozone or Advance to get the Sensor it will come with a warranty as well.
Also Ive read its the moisture upon O2 sensor heat up that kills it. You should start your car let it idle for a few moments ensuring moisture is gone then turn the sensor on to heat up.
Old 07-04-11, 08:50 AM
SC300_704
SC300_704's Avatar
awesome, i didn't think autozone sells it but i just checked th site and they carry it in stock where i live at.
hoothoot
11-28-19 05:01 AM
S160dre
08-11-16 06:36 AM
SMUChris
12-17-12 03:50 AM
PES300
10-22-05 11:50 AM
Quick Reply: Innovate Wideband Sensor
