1jzgte bucks...
Yes sir.. when I came across the wire and looked at it and grinned.. We had a little talk.. lol
Thanks Bro.. As for your situation, I am not sure but lets start with a few questions:
- All stock?
- Any electronics tapped into the ECU? If so, double check your connectors.
- Checked your grounds?
- Checked coilpacks? Just as a precaution, I used heat shrink to wrap the coilpack stem to prevent arching.
- Check your map sensor?
Awesome man, glad you got your ride fixed. Im still trying to figure out my headache still. I tried Recappping the ECU, new plugs, and a new tps but still wont boost over 5lbs and the damn thing stutters.
Would disconnected wires on the body plugs cause this? I have 2 wires that are disconnected at the body plugs and dont know where they go
- All stock?
- All stock?
- All stock?
-Its all stock
-No other electronics
-Grounds are all good, least I think they are.. I will double check
-I heatshrink the stems on the coils also, theres 2 hairline cracks on top where it bolts to the bracket. Im not sure if its the problem
-Still trying to figure how to test the MAP sensor
-Its all stock
ivie08
RX - 1st Gen (1999-2003)
08-21-10 10:24 PM
