No boost but can hear the turbos spinning??
Hi guys and girls, just joined as i am about to buy a soarer tt off a friend.
Anyway there is an issue with it and its the reason i am getting it cheaper than it should be, but just curious as to what the issue is...
Basically its not boosting properly it gets to -0.2 on gauge and that is it it makes all the right noises just wont boost!!!
Now this is after he blew the last turbos up and has since bought these 2nd ones, which he said had no play in the shaft and both moved freely when spinning by hand..
So he had them fitted and now it doesn't boost car runs great and you can feel it pull just not hard at all but it trys..
The things i have looked at with him (trying to get him to fix it) but now he just wants rid.
changed all the vac pipes to new ones and checked the cooler pipes/wastegate hoses etc and tightened them up even lubed up the bov. we cant hear any boost leaks at all....
We can get slightly more boost out of it if we take out the restrictor but that still doesn't manage +0 on the gauge
The gauge is correct and accurate too.
My conclusion now i am gonna buy it is, it has to be the wastegates or something not put back on the right way?
Anyway any help advise would be great and highly appreciated so thanks in advance Gerry
For it to be that low (assuming your gauge is accurate), it sounds like you've got an open IC pipe somewhere. I would think an open wastegate/boost controller problem would still allow for more boost than that. I've got to say, I wouldn't buy someone else's mess though, even a friends, unless you have an exact understanding of what is wrong with it. Let him fix it or else make him sell it for a small fraction of what it's worth if it worked properly.
.02
.02
How do you perform a boost leak test??
Intercooler is a new aftermarket jobbie
Its wierd hey the turbo/turbos do make a screech like noise and the car changes gears early because of this i think..
ie it changes around 4000rpm when on boost but under normal load nice and high as normal say 7k..
Just bypass all the stock sequential stuff first wire it open so both turbo are on at the same time and if then you still have no boost, you either have a huge boost leak or turbo are screwed or could be wastegate problem too. But to start I try to get boost first
Car is cheap though lol
Would the actuators cause it to not boost properly then??
he still has the other old turbos with actuators on that i could swap over???
A stuck open actuator can cause it to boost improperly, but having them both stuck open would be highly unlikely. Are you 100% sure the I/C pipes are hooked up properly and not leaking? IAC tube (the air hose that goes around the back of the engine) hooked up to the intake pipe? And are you sure the turbos he put on are not junk? If one of the turbos has blown fins (a common issue) it won't make boost period, even if the other turbo is fine. If one of those turbos is "screeching" like you describe, more than likely a turbo is junked.
he assures me the turbos he bought were spot on??
Ie minimal play in the shaft all fins looking good etc
All hoses checked and the majority replaced.
With the actuator i was thinking maybe just on stuck and not opening closeing?
it -sounds- like it whould be worth the buy if -all- it has is this leak
i am kinda good at diagnostics, try this....
on the pre intercooler pipes block them of one by one and test the psi if you dont have pressure rite at the turbo cold pipe then you have your problem!
Had the same issue on the 300ZX TT... took the charge pipes off and the body shop had dropped a bolt in the passenger pipe when it was off and it had lodged it self in the compressor wheel.
It spooled, heard BOV activate, but no boost on the gauge.
Going down today to swap over the actuators and check the back turbo aint siezed or anything..
The deal is the same with him weather i fix it or not....
Before you pull the actuators see if they are opening and closing properly. As complicated as it seems they are in fact really simple. After you check the actuators pull the cold pipe off and block it with your hand off the intercooler. Next step would be to pull the hot pipes off and check out the compressor wheel on the two turbos, sometimes they shear off and then you have the exhaust turbine spinning and not producing cfm or the other way around but I'm sure you get it. Good luck ! Tell your buddy that your not going to fix a car unless he knows that after completion it's yours. I did a full turbo setup and spent two weeks on a buddies car when I was younger that I was going to buy and he sold it to someone else. Short story a bat was involved
