EGR valve cleaning
Old 04-06-11, 02:42 PM
dvny
dvny's Avatar
Default EGR valve cleaning
I'm cleaning the EGR valve and just noticed that I cannot run a wire to clean the small tube where the hose to the modulator/filter is connected. Is this normal or is the tube clogged?
Btw, the car is 92 SC300.
Thanks for all your replies.
Old 04-07-11, 04:07 PM
dvny
dvny's Avatar
btw, there is a screw with a philips head and it looks like this tube can be removed. I tried to take out the screw but the tube won't move . Any suggestions?
Old 04-07-11, 04:37 PM
NEbiker10
NEbiker10's Avatar
I need to do this too...been putting it off for a while
Old 04-07-11, 06:13 PM
6SOARER
6SOARER's Avatar
There are 2 10mm or 12mm bolts at the bottom of the tube. Its a PITA to get to, I only could get the top bolt loose while the motor was in. Good luck getting to that lower bolt
BTW, if you cant get the tube loose try using a coat hanger to clean it.
Old 04-07-11, 08:50 PM
ArodDaLob
ArodDaLob's Avatar
yeah, you'll have to unbolt the whole pipe at the bottom. it's a complete pita, and you'll need to experiment with a few combinations of extensions to reach it. my hand was cut and bruised up pretty badly after this. but i passed smog so it was worth it.
Old 04-07-11, 10:09 PM
vietunit
vietunit's Avatar
Oh boy, that sounds fun
Old 04-08-11, 12:03 AM
dAng_bAy
dAng_bAy's Avatar
I was debating on trying out that Amsoil Powerfoam to clean it out...
Old 04-08-11, 07:35 PM
dvny
dvny's Avatar
Thanks... I was able to loosen the top bolt (really took me some time to figure out how) and took the EGR valve out. but the tube in question is the small one attached to the valve where the vacuum modulator connects. I'll try to post a pic later.
Old 05-02-12, 09:48 AM
CrazySC300
CrazySC300's Avatar
I'm in the process of getting this done as we speak, My car can't pass smog because of the high NO PPM numbers...Thought it was the Catalytic converter, Boy was I wrong! (Costly mistake) The emissions numbers were even higher after the new cat was installed...So obviosly, It's the EGR system.
I've been needing to this for the longest time, I look back at some of my old smog test papers and realized that back in '10, I barely passed NO PPM emissions.
Old 05-02-12, 01:54 PM
GS4_Fiend
GS4_Fiend's Avatar
Did u read my response from other thread!
Old 11-28-12, 02:31 PM
SC300NW
SC300NW's Avatar
In response to the very first question, you can't go through the lower non-painted elbow because this part is vacuum operated and the plunger is in the way. To see if it's funtional you have to suck on the top tube and the plunger inside should rise. If not, then you'll have to find a way to support the plunger in vacuum mode (plunger up) and gently clean through the tube. Or, you can buy another one ($$$).
Hope this helps anyone.
jbw
04-25-23 12:49 PM
badboylx04
GS - 1st Gen (1993-1997)
04-17-13 09:47 AM
craiger28
05-19-09 09:28 AM
RPH74
Maintenance
06-28-04 08:18 PM
GOLDSc300
02-16-04 10:00 AM
Quick Reply: EGR valve cleaning
