Obx twin turbo kit
Old 03-08-11, 10:48 AM
soardrft
soardrft's Avatar
Default Obx twin turbo kit
Has anyone tried it out? Any dyno numbers? What's the response like? I have a single gt35 on 1jz and honestly I'm not impressed. So i want to scratch the single idea and do something different for a change.
Old 03-08-11, 01:56 PM
xspsi6
xspsi6's Avatar
Obx=Chinese junk! Imo nothing good is going to come of that.
Old 03-08-11, 02:03 PM
BartleDoo
BartleDoo's Avatar
What are you not impressed with? You should be making some good power.
Old 03-08-11, 04:04 PM
xspsi6
xspsi6's Avatar
If it's a chinabay gt35 then it most likely leaves something to be desired, I have seen 35r powered cars in the single digets.
Old 03-08-11, 04:35 PM
soardrft
soardrft's Avatar
At the dyno I made 349hp & 327tq @ 11psi(something around there). What I'm not impressed with is the spool. I turned up the boost to 18lbs but still felt laggy. Don't get me wrong the car pulls really hard when in boost, but I assume doing a twin setup will give me a better response. I have searched but have yet to see dyno sheets from an upgraded twin turbo.
Old 03-08-11, 06:05 PM
stockhatch
stockhatch's Avatar
Originally Posted by xspsi6
...I have seen 35r powered cars in the single digets.
So like 9rwhp? Sorry, couldn't resist.
OP, as already mentioned, run far away from the obx twins.
Old 03-08-11, 06:57 PM
SChema
SChema's Avatar
Twin turbo in parallel is not going to give you better spool, may actually be laggier than a comparable single in flow.
What A/R are you running on the hot side?
You want spool? Go with a smaller A/R.
You want good top end? Go with a larger A/R.
Double edged sword, you gain at one end but lose in the other.
Then again, nothing two-step and brake-boosting can't fix.
Old 03-09-11, 07:46 AM
soardrft
soardrft's Avatar
Thank you for that answer. I will have to look into rebuilding a 2jz bottom end and hope to see better spool results. My a/r is .63
Old 03-09-11, 09:31 AM
cartmill
cartmill's Avatar
at what RPM do you hit full boost in 4th gear?
a .63 t4 should be a good match for the 2.5
you coudl always downgrade to a t3/t4 turbo, but you'd have to get a new manifold.
Old 03-09-11, 09:55 AM
soardrft
soardrft's Avatar
I'm running a t3 currently and according to the graph I hit full boost just above 4k. But I also have another sc with the stock twins and that car in my opinion is better for street. I heard of doing mods or even going to usdm twins, but nothing concrete on spool. I would love to see dyno graphs on cars with modded 1jz turbos or even usdm turbos.
RgSc
SC- 1st Gen (1992-2000)
08-05-12 06:01 PM
RyanV
23
05-09-12 02:11 AM
kikcaffine
03-23-11 08:27 PM
Chaser07
20
09-19-07 09:26 AM
rawfish
09-19-06 08:18 PM
Quick Reply: Obx twin turbo kit
