Help sc400 1992
Old 03-03-11, 11:51 AM
NSeagle78
NSeagle78's Avatar
Default Help sc400 1992
I am a 54 year old challenged machanically. My car does not always start. I just changed my up front sensors with ebay 4 wire knock offs. I am still getting codes 13, 21, and 28. RPM signal, Main 02s/Heater signal and main 02s again. Where are these parts located at? I know where the sensors are located. Also any other advise is appreciated.
Old 03-03-11, 03:12 PM
1WILLY1
1WILLY1's Avatar
code 13 from my experiance can be a tricky one------your going to want to check your cam sensors and also your crank sensro while your at it.
Your problem probably lies there somewhere.
Old 03-03-11, 03:21 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I have the PDF file for these codes at home. I will chime back in tomorrow and let you know further of what I find.
Old 03-03-11, 07:35 PM
NSeagle78
NSeagle78's Avatar
Default 92 sc400
Thanks everyone also what is a crank and cam sensor and where are they located?
Old 03-06-11, 08:19 PM
NSeagle78
NSeagle78's Avatar
Default Bump
Bump help still need information
tenac2215
04-05-14 07:28 PM
NSeagle78
Maintenance
03-03-11 09:30 PM
GSLEX99
07-28-09 05:11 PM
phinicben
09-10-07 12:44 PM
Quick Reply: Help sc400 1992
