Resealing w58?
Old 01-12-11, 12:58 AM
S.F. Goat
S.F. Goat's Avatar
Default Resealing w58?
Getting ready to pull the engine n tranny. The w58 on this car has always leaked from between the casings. Are there gaskets between the casings or does it just use liquid gasket maker? If it's just liquid gasket maker, can I just slightly separate the bodies and reseal it?
Looks like someone has been inside the tranny before and resealed it with orange RTV. Tranny shifts great, just stubborn on the 2->1 downshift for the first few shifts on a cold morning.
Any links on a how-to for a rebuild?
Old 01-12-11, 04:16 AM
stockhatch
stockhatch's Avatar
You will need to split the cases completely so you can clean the mating surfaces well. Then use the orange toyota fipg to seal it. You can buy a tube of that at the dealer or at driftmotion.com.
Here is a link to the manual that explains the process of opening the trans up. This includes both W58 and R154 info:
http://www.swaqvalley.com/TSRM/14_MT.pdf
Old 01-12-11, 12:21 PM
S.F. Goat
S.F. Goat's Avatar
That's exactly what I needed. Thanks.
Old 01-12-11, 12:38 PM
RedPhoenix
RedPhoenix's Avatar
Its stubborn on 2->1 because 1st is not syncro'd... you need to rev match to get it in or go slow enough.
Old 01-12-11, 12:41 PM
stockhatch
stockhatch's Avatar
1 is syncrod for sure. I can show you the pic of the syncro if you like.
Old 01-12-11, 01:11 PM
RedPhoenix
RedPhoenix's Avatar
A lot of info online says first is not syncro'd... i have one torn apart, just never looked at it that much... ill look at it later.
Old 01-12-11, 01:16 PM
stockhatch
stockhatch's Avatar
Yeah I don't know where people get that. If it wasn't syncro'd it would grind, or engage with a "CLANG!" like a dog box since its constant mesh. 1st is stubborn because its such a low ratio that the syncro can't do its job until everything else has slowed down enough for it to keep up.
Lextrd016
Performance
16
01-21-13 05:32 AM
speed6
02-08-08 11:22 PM
Jacj3
16
05-06-07 09:38 AM
Quick Reply: Resealing w58?
