DIY: SC400 (A340E) Shift Solenoid Replacement
Old 01-12-11, 12:31 AM
E365
E365's Avatar
Default DIY: SC400 (A340E) Shift Solenoid Replacement
I've seen lots of information about failed shift solenoids, but I haven't seen any pictures. Thought I'd join and post some info.
Car: 1992 SC400 10/91 Build.
Transmission: A340E
Problem: "O/D Off" Light flashing, odd shifting (owner mostly complained about high revs before upshifts, I didn't get a chance to drive it much myself but I did get the O/D Off light after just a mile or so). I got transmission codes 63 and 67.
Tools/Parts Needed:
• 8mm socket for one valve body (bracket mount) bolt
• 10mm socket for transmission pan bolts and valve body(bracket mount) bolts
• 10mm open-end wrench for negative battery cable clamp
• 14mm socket for transmission drain plugs
• 3 qts. ATF. I used Coastal Multi-Vehicle Synthetic Blend Automatic Transmission Fluid from AutoZone for $3.99/qt. It says it meets Toyota T-III and T-IV / Lexus specs.
• Rostra Solenoid Kit #67420CK. Fits A140 / A240 / 241E / A340 / A340E and maybe more. It was about $112 with shipping from Makco Transmission (through their eBay store).
Procedure:
It's really a pretty simple job thankfully! But, it is messy like all automatic transmission servicing when you take the pan off. I did it with just the front wheels on ramps but it was a very tight squeeze.
Disconnect negative battery cable
Drain ATF into clean container and measure. I use this measurement to determine how much new fluid to put back in. I've found this method makes refilling MUCH easier, assuming it was at the proper level before you started.
Remove transmission pan bolts and carefully lower the pan from the transmission.
Oops! So much for an accurate measurement of how much I took out! With the front end in the air and the shallow pan, you're bound to spill some.
Old 01-12-11, 12:34 AM
E365
E365's Avatar
Here's what you see once the pan is off.
Shift solenoids
Lock up solenoid and some other solenoid???. I had a hard-time figuring out which solenoids I needed to buy from looking at the real Toyota diagram. They listed three different "shift solenoids" and one lock up. I figured the Rostra kit had it figured out so I went with that. Plus the price. I needed to do this on-the-cheap for a guy.
Old 01-12-11, 12:54 AM
E365
E365's Avatar
Old solenoids and new universal ones. You can see they are not the same design....
The kit comes with a handfull of different brackets depending on which transmission you are workign with. This is the one this transmission needed, but I did not like the fit much. I needed to enlarge the mounting holes a tad to secure the solenoids better. I'll get into that more later....
Removing them and replacing them is a breeze. The old ones are attached with a single bolt (10mm head?). Remove the bolt, unplug them from the wiring harness and pop them out of the holes they are seated in. Lightly coat the o-rings of the new solenoids with some ATF and insert them into their holes.
The bracket that's included is the only one that could possibly fit (it uses three bolts, not ones that secure the original solenoids) so it has to be the right one. The problem with the bracket is that it doesn't keep the forward-most solenoid in its mounting hole securely, hence the need to elongate the orginal hole and allow the bracket to move closer to the hole in which the solenoid mounts into. I ran into the same problem with the rear solenoid, except worse. This required two plastic washers (you can see them in the picture below) to make up the space between the bracket and back of the solenoid.
Also, when the bracket is bolted to the valve body, the bracket starts to crush the rearward solenoid, taking it out of alignment with its mounting hole. This required two washers between the valve body and rearward most mounting point of the bracket. Once I modified and shimmed the bracket I was pleased with how secure and straight the solenoids were installed. If this were my car and I was willing to pay the money for the real Toyota solenoids I would have. Especially if you are going to keep the car for a long time.
Using a new gasket (and I used Permatex Ultra Grey) mount the pan back in place. *** Make sure the dipstick tube seats into the upper portion of the dipstick tube beofre you start bolting the pan back in place *** Like this: Name:  ss8.jpg
Secure the bolts according to the Permatex label if you used it. Bead, tighten until it startes to squeeze out, wait 1 hour and tighten an additional 1/4 to 1/2 turn.
Add the new fluid. Take car off ramps, start and run through all gears slowly. Stopping at (P)ark, check the dipstick. It should be in the cold range. If so, drive the car gently for 20+ minutes to get the transmission up to operating temp. Recheck fluid and adjust to be in the Hot range.
That worked for this car at least, no promises! "O/D Off" light does not come on at all now and it seems to shift perfectly, although my 20 miles test drive was in the snow so I couldn't push it hard. Also this car had a TRAC light (constantly on) and codes 43 and 41. The light only comes on now when traction is activated and goes out immediately after like it should (I suppose!?). Either the transmission fix fixed this, or maybe more likely, disconnecting the battery reset the computer and the system work as it should now.
LALexusOwn (03-05-18)
Old 01-12-11, 01:42 AM
iridebmx
iridebmx's Avatar
basically if you buy the oem ones its a breeze.
awesome DIY! nice to know its this easy to do. i may change them once i get my tranny serviced.
Old 01-12-11, 02:45 AM
E365
E365's Avatar
Yeah, I probably spent half my time on the whole project just figuring out the bracket and modifications.
Old 01-12-11, 03:45 AM
titanSC
titanSC's Avatar
Great DIY! That would help a lot of people facing similar problem with the O/D light blink. Thanks for taking the time to document this.
Old 01-12-11, 07:34 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
These are the write ups that I like to see. These are the ones that ought to be stickied immediately. Thanks man.
Old 02-10-11, 01:01 AM
FlyRyde
FlyRyde's Avatar
So nice to have found this! I need to do this asap so I can sell the sc4 for a nice clean sc3
Old 02-10-11, 09:00 AM
brad11140
brad11140's Avatar
http://www.electricaladvantage.net/a...olenoid-1.aspx
I bought this kit for my 4Runner and the bag says A340 E/F/H. Since the SC400 has the A340E I cant see why it would not fit. The brackets are also like the OEM, so no headaches modifying the mounting bracket.
Good luck!
Old 06-19-11, 08:10 AM
305ls400
305ls400's Avatar
im going to be doing this for my 1992ls400 will i need the Lock up solenoid also
Old 07-01-11, 06:58 AM
mktbully
mktbully's Avatar
Originally Posted by GSXMike
So I take it that grey rectangular piece with the screen is the "filter"? I am trying to get clarification if these transmissions have an actual filter that can be changed.
I have a 92 sc300 that is shifting a little rough. Not too bad but not smooth. I'd like to do some preventative maintenance before the trans calls it quits.
I am changing the fluid tomorrow. If it doesnt help that much would changing the solenoids help make it shift smooth again? Should I bother replacing that screen/filter part?
Thanks.
if you already have it opened up then might as well swap the filter.
yes it's that big gray square thing.
Old 07-01-11, 12:30 PM
V8drummer
V8drummer's Avatar
I thought I needed new solenoids a while back, but just changing my fluid and filter make the transmission shift like new. I however, didn't have the flashing OD light.
I'm pretty sure my Sc400 had the a341e though, because the solenoids were much longer.
Old 07-09-11, 08:13 AM
305ls400
305ls400's Avatar
i change my solenoids i had the code 63 and 67 i change them and now i still have the same problem the od lights keep flashing. i change the filter also i took of the battery and the fuse in the engine to reset the computer but it didnt work i still have the same problem like if i have not change anything. what can i do
Old 07-10-11, 06:22 PM
sethjon
sethjon's Avatar
Whats the height of your ramps when you did this? My ramps are not high enough to really be able to fit under the car and work. Whats the secret?
Old 07-11-11, 02:14 AM
E365
E365's Avatar
Those were the 12,000 lbs. Rhino ramps which have a 6.5" lift. I do remember it being a very tight squeeze under there.
Quick Reply: DIY: SC400 (A340E) Shift Solenoid Replacement
