instrument lights won't shut off SC400 1992
Old 12-25-10, 06:48 PM
achap
achap's Avatar
Default instrument lights won't shut off SC400 1992
Hope someone has run across this problem or similar. It started with my alarm on my 1992 SC400 going off constantly, then a day later, the backlight on the instrument cluster, brake, odometer/clock and oil pressure light don't shut off when I shut the ignition switch off. Everything seems to run okay when I start the engine, though I have now disabled the alarm system by bypassing the trunk switch.
I noticed too, that the automatic steering tilt away isn't working. I can move it manually though.
Any help would be appreciated
Old 12-29-10, 08:48 PM
darian28
darian28's Avatar
samee thing happened with mine
i took out the cluster to see what was wrong
it was not connected correctly and there is a fuse called the alt sensor try to change that and see what happens
pm me what happens??
Old 12-30-10, 12:54 AM
achap
achap's Avatar
Thanks, I'll try that this weekend and let you know what happens.
Harsh2000
07-27-17 01:43 PM
Hintonjr
10-23-16 07:46 PM
groverwood
SC- 1st Gen (1992-2000)
18
10-04-12 08:27 AM
attis
04-25-06 08:59 PM
Quick Reply: instrument lights won't shut off SC400 1992
