SC300 OEM Differential
Old 12-03-10, 10:46 PM
mdmaniac
mdmaniac's Avatar
Default SC300 OEM Differential
Seems like I just can't get a straight answer from anywhere.
What is the Stock/OEM differential in a 1997 SC300 (5-spd)? Is it a Torsen, like in the Soarer? Or is it some non-TBD, non-LSD open diff?
Thanks!
Old 12-03-10, 10:48 PM
CrazySC300
CrazySC300's Avatar
All SC's here in the U.S (Be it 5spd/AT 300 or 400) from '92-'00 all came with open differentials.
SChema
SChema's Avatar
Open diff, SC's never got the limited-slip option.
Old 12-04-10, 05:32 PM
gtsfire
gtsfire's Avatar
What are the ratio's?
Old 12-04-10, 08:46 PM
nivek5sfe
nivek5sfe's Avatar
the 5speed is a 4.08 i believe, im not sure if the auto is the same
Old 12-04-10, 11:37 PM
mdmaniac
mdmaniac's Avatar
Thanks. So, question is, what's a better set-up? Limited Slip? or Torque Biasing Diff?
Old 12-05-10, 06:47 AM
Carfreak70
Carfreak70's Avatar
I like LSD's. But in more into drifting and like it when it grabs. Considering TRD made theirs a limited slip, I would go with that.
Old 12-05-10, 09:10 AM
Wreckless
Wreckless's Avatar
92-97 5-spd's got the 4.083:1 ring & pinion
92-00 auto's got the 4.272:1 ring & pinion
SC's were never offered with a factory installed LSD in the US.
The MK4 Supra community regularly removes the OEM Torsen LSD to replace it with the Clutch-type TRD LSD. The clutch-type LSD is a lot more predictable and stable, and doesn't get twitchy at high HP levels like a Torsen does.
TRD, Kaaz, Carbonetic & OS Giken, all make an outstanding diff. Can't go wrong.
If you're into road racing, everything I've read points at the OS Giken being ideal for all the ways you can tweak & tune it. If you just need good traction lockup for street/driving purposes, the TRD or Kaaz 2-way are awesome.
Old 01-20-14, 02:21 PM
Pilot300
Pilot300's Avatar
so expencive for sura lsd... heard gs400 lsd can work with minnor mods
Old 01-20-14, 07:24 PM
hmhatch
hmhatch's Avatar
You picked the wrong car if you think spending around a grand to have LSD is too much.
No such thing as a gs400 LSD.
Old 01-20-14, 08:32 PM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
^^ This. Generally a Torsen LSD in a 3.769 pumpkin goes for $1k. A TRD 2-way that requires installation is $1k or so. Rarely I see bare TT Auto or Soarer T-2 Torsens for around $650-$800 that also require installation. It's comparable to what most other cars have as NEW aftermarket LSD options which are often starting at $1,000 and go to an average of $1,800 or more. Pick any popular performance chassis and price out a Quaife, OEM Torsen, or clutch types like Kaaz or semi-clutch types like an OS Giken. The prices are up there with few exceptions.
Getting any type of LSD installed in an SC or Supra differential shouldn't be a big sweat. I got mine installed with new shims and bearings for $350 from a reputable specialist. Well worth it considering how old these things are becoming.
Also, comments above by Wreckless about about different types of LSD's and their most advantageous uses are spot on.
Old 01-20-14, 08:48 PM
LEXXIUM
LEXXIUM's Avatar
The least expensive ways to go is TT auto diff, it should drop right in with your existing ring gear. I think I read that on sf somewhere while back.. I scored this low mileage one on ebAy while back from Titan Motorsports almost next to nothing haven't found a reputable shop to drop it in.
Old 01-21-14, 05:58 AM
99SC42
gte & na-t
99SC42's Avatar
TRD auto LSD is $1280 , you need 2 bearing $70 , 2 orings $10 and the rtv.
TRD lsd is stronger and when it breaks it still keep both wheels spinning and track straight and with the torsen you will be all over the place...
Old 01-21-14, 12:24 PM
hmhatch
hmhatch's Avatar
You sure that's not a 6 speed diff? If so it will not work with your ring gear.
Old 01-21-14, 02:14 PM
myLEXsc400
myLEXsc400's Avatar
which LSD is a direct drop in for a 97 oem w58? The TT auto diff?
Quick Reply: SC300 OEM Differential
