2JZ + Tremec T56 ?????
Old 10-27-10, 07:21 PM
  #31
YeA 2jZ
YeA 2jZ's Avatar
Found some info on Clutch Flywheel setup. not sure how accurate it is, I am just finding info and copying onto here for possible clarification or confirmation that its correct or true......
Originally Posted by stephenz
what clutch can I use when using a t56 with my 2jzgte?thanks for your time
Originally Posted by williamb82
titlton triple plate 7.25in diameter and tilton 2j flywheel. make sure the discs are splined for the t56 you use. and youll need an internal hydraulic slave as well.
cool,where can i talk to someone about that clutch,and price?
titan sells the tilton flywheel i beleive. the clutches can be bought anywehre just about. got mine used to use for mockup and just going to replace the metalic discs with cermatalic ones. the metalic will work fine for when i mock it all up out of the car though.
Old 10-28-10, 04:59 AM
  #32
BenStoked
BenStoked's Avatar
Originally Posted by YeA 2jZ
I found a pic of someone that had the adaptor plate already and had it for sale on SF
Now I was reading around and some guys had posted saying that the MUSTANG T56 has overdriven gears for 5th and 6th thus making it pretty much kaka for higher speed. BUT the Aussi guys say that you MUST use the CAMARO T56. Is it because of what has been said about the Mustang T56 to be true ? Is it possible that other Chevy type T56's have this weird 5th and 6th ?
all t56 have overdriven 5-6.
http://en.wikipedia.org/wiki/Borg-Wa...Identification
Old 10-28-10, 10:27 AM
  #33
Ali SC3
Ali SC3's Avatar
I think the mustang one they said something was cable driven. pretty much most parts on the mustangs are not as good as the ones they put on chevys and other cars.
Camaro t56 sounds good to me, and that ad says the viper one works too. to me this is great news.
*edit* the difference is that the camaro is concentric and the mustang one is not (like your friend said on page 2).
i found this info helpful to understand what the means:
http://www.camaros.net/forums/showthread.php?t=98387\\
note the viper has a longer input shaft than all the other T56's, but it can be swapped out with the old style (see post 2). not really sure which length we need.. lol
Old 11-09-10, 09:17 PM
  #34
Nova
Nova's Avatar
tremec t56 trans are also in cobras, vettes, and vipers
mustangs are cable driven but that is not nessaccerly a bad thing. cable clutch is better for the 'feel' and it might be easier to route a cable then plumb clutch line
also in for interest
Old 11-10-10, 09:02 AM
  #35
rpk2012
rpk2012's Avatar
In as well, but here for both 1u and 2j.
Old 11-11-10, 11:47 PM
  #36
BAD954BOI
BAD954BOI's Avatar
so if i'm reading this correct all you would need is the adapter plate made to attach an LS1/Viper style T56 up to a JZ engine, the Camaro t56 and a custom drive shaft to make it happen.... but what about the tranny mount?
Old 11-12-10, 12:07 AM
  #37
kwg
kwg's Avatar
subscribed! this is useful information
Old 11-12-10, 06:21 AM
  #38
scmissle
scmissle's Avatar
I'm new to the board, and I like this thread, very full of options for us all. However, being a T56 can be had for as low as $1800 brand new, wouldn't the cost to adapt the bell housing, custom flywheel and clutch, and a custom drive shaft put it all overboard of the $3500 for a used V160 or maybe even the $5500 brand new price of a V160? I love the T56 gearbox cause it has a lot of aftermarket products and gear sets, but for those pushing the 650HP 600 FT/LB torque I would not recommend this box. I have seen them snap under that kind of power.
Old 12-22-10, 08:09 PM
  #39
Nova
Nova's Avatar
bumping this thread back to life. do we have any more info? id also like to know if anyone has tried a cable driven clutch setup in out cars.
Old 12-23-10, 09:29 AM
  #40
Ali SC3
Ali SC3's Avatar
you forgot to factor in the pirce of a clutch for the V160 (very expensive). But I agree on the power levels because there is a power limit where the T56 will give out and the V160 reigns supreme
Old 12-23-10, 10:07 AM
  #41
JakeBreyck
JakeBreyck's Avatar
If anyone is planning on doing this i could do a custom clutch to make this work. pm if interested.
Old 06-19-11, 06:08 PM
  #42
Cashflo
Cashflo's Avatar
Sorry to bump an old thread, but I want some more information involving this!
Old 06-19-11, 06:24 PM
  #43
MDSC
MDSC's Avatar
please buy a r154 or a used v160 theres one for sale right now in the classifieds, t56 is garbage
Old 06-20-11, 01:49 AM
  #44
BAD954BOI
BAD954BOI's Avatar
please do explain why they are garbage?
Old 06-21-11, 03:54 PM
  #45
sebasc300
sebasc300's Avatar
Besides the fact of it being garbage, why spend 3k+ for a tranny swap that can only hold 550hp?
Get the v160.
The v160 is known to hold upwards of 1300hp stock. This really is a no brainer guys.
end thread.
Quick Reply: 2JZ + Tremec T56 ?????
