2JZ + Tremec T56 ?????
Old 10-26-10, 10:51 PM
shern
shern's Avatar
Originally Posted by YeA 2jZ
Where does a Soarer R154 measure in, compared to the pic ?
From my swap thread. Remember, this is with swan style shifter. Looks like the standard shifter location around 29" would work perfectly. No remote mount shifter needed.
R154 Soarer shifter extension
Old 10-27-10, 01:04 AM
aka paco
aka paco's Avatar
Thought i made a thread on this before lol but actually just mentioned it in a thread about the garbage X-runner 6 speed..
ScottURnot mentioned a guy in AUS doing it though
As awesome as the V160 is, I would really like to see 2jz/1uz owners get some kind of T56 adapter kit going, used T56's are so cheap compared to V160's Brand new T56's are still almost half the cost of a used V160..
A V160 may be bulletproof, but a T56 will hold 700WHP no problem and can take some abuse!, and are plentiful!!!
it'd be nice to have T56's as an option, 2jz owners already use Chevy TH400's so whats the big deal..
V160 clutch prices are insane as well!
Old 10-27-10, 01:44 AM
TURBO819
TURBO819's Avatar
Default Dodge Viper 6 speed with Corvette shift ****.
I like this possibility also. See Post # 29
https://www.clublexus.com/forums/per...-complete.html
Old 10-27-10, 04:57 AM
97-SC300
97-SC300's Avatar
Originally Posted by turbo819
i like this possibility also. See post # 29
dodge viper 6 speed with corvette shift ****.
how was this accomplished? The viper 6 speed on a 2jz? Any more info?
Old 10-27-10, 05:08 AM
plex
1UZFE/2JZGTE
plex's Avatar
I was considering the T56 option too but ran into same issue with adapter plates. I got lucky with a V160 at a good price. V160 clutch prices aren't as insane as you think. There's the $5K Tilton but also many single disk options that can be had for less than $900.
Old 10-27-10, 05:22 AM
YeA 2jZ
YeA 2jZ's Avatar
so looks like at 29" the Camaro 6-speed is the one to get, hmmm getting interesting here.....
Old 10-27-10, 06:39 AM
BartleDoo
BartleDoo's Avatar
Is that with bellhousing and adapter dimensions accounted for, though?
Old 10-27-10, 07:23 AM
shern
shern's Avatar
That R154 measurement is from edge of bellhousing to shifter. I would imagine the adapter plate would run between 1/2" to 3/4" thick. We're still in the ballpark.
Old 10-27-10, 07:25 AM
99SC42
gte & na-t
99SC42's Avatar
09 Viper Trans
Length: 44.03 inches
Width: 22.01 inches
Height: 24.01 inches
Weight: 152 pounds
Part#68049868AA
Old 10-27-10, 08:14 AM
YeA 2jZ
YeA 2jZ's Avatar
This is a direct cop and paste from a post made on v-eight.com, I have e-mailed them and awaiting info back.............
Part Description:
TREMEC T56 6 Speed manual adaption
UZ Model Compatability:
ALL Toyota JZ Engines
Specifications of Part:
Flywheel ; 6061-T6 Alloy with AMOUR Plate Face.
Adapter ; 6061-T6 Alloy
Clutch Kit ; RUSH Specific Modulated Clutch Design
Drive components ; 2 Setups ( From 500Hp Rating )
New Short Shifter ; RUSH Specific to customer / car / application.
Hydrolics ; Braid and / or Steel
Manufacturers Usage Recommendation:
All JZ Engines in all applications.
Modulated Clutch design ONLY.
Other/Modified Usage Suggestion:
Specific Indications for Use of Part:
Specific Contraindications for Use of Part:
Measured Benefit of Part:
Not available as yet.
Identified Problems with Part:
Selecting inappropriate Friction setup for inappropriate application.
Ie ; Order Organic plate then melt it doing Drags / Track.
Suggestions for Improvement:
None.
Approximate Retail Price:
TBA
Retail Source & Contact Details:
RUSH IMPORTS
5 Silva Ave
Queanbeyan
NSW 2620
Ph 02-6284-3111
sales@rushimports.com.au
Overall Rating:
TBA
Part Image
Not Available.
Old 10-27-10, 08:26 AM
YeA 2jZ
YeA 2jZ's Avatar
more info on supramania
http://www.supramania.com/forums/sho...rest..../page8
and I am not a member of the australian site but mabey someone else is and can get the info from here (click link in second post)....
http://www.toymods.org.au/forums/showthread.php?t=55978
Old 10-27-10, 09:06 AM
Ali SC3
Ali SC3's Avatar
I think were overlooking something here. from the description it seems that the t56 bellhousing is not used. so you can't use those lengths for the T56 directly to fit the shifter in this case.
to figure out shifter length here:
unless I got it all wrong, this adapts the t56 to a toyota automatic bellhousing, so it will definitely change the length of the transmission.
so i think we need to compare the length of the (auto bellhousing + adapter plate) to the bellhousing of the T56.
the difference of the 2 would be added or subtracted from the total length. right???
that number we need to try and get as close as possible to the Ideal SC length (someone said 29" above).
Old 10-27-10, 01:34 PM
YeA 2jZ
YeA 2jZ's Avatar
Damn this sux the thread got moved to this section oh well, got a reply back from the Aussi guys.....
"Hi Kevin,
The JZ setup is just about completed.
What would you like to know mate ?
It ONLY takes the Camaro Internal Slave ( Concentric ) T56, it does not suit the Mustang etc with the cable clutch.
You have a choice of,
Twin Organic Clutch
Twin Metalic Clutch
Both are good for Street / Track, depending on the drivers needs.
Of course the organic is nicer on the street.
All I need to ship from Australia is,
Flywheel
9" Clutch System ( Which will be backed up in the USA very soon )
Adapter Plate
Driveshaft Yolk / Uni / Weld End
Rest of the parts I can advise of where to get in the USA, depending on the application of the install.
Regards,
Neil Griffiths
Director."
Old 10-27-10, 05:49 PM
240sxrb30
240sxrb30's Avatar
Default 2jz+t56
oh boy this is awesome news. me and my bro talked a lot about putting a t56 behind the 2j. now after many folks saying to just stick with the v160 we have a much cheaper option. so do we need to use the ls1 camaro or can we use any of them? can we get a comparison with the viper tranny for the length?
Old 10-27-10, 07:13 PM
YeA 2jZ
YeA 2jZ's Avatar
I found a pic of someone that had the adaptor plate already and had it for sale on SF
Originally Posted by bigzavs
ITEM: 2JZ/1JZ to T56 adapter plate and bellhousing
PRICE: $300 shipped obo
DESCRIPTION: Brand new adapter plate made to attach an LS1/Viper style T56 up to a JZ engine. i mounted it on the transmission once. the bellhousing is in good shape, just not quite so new. afaik this is one of 6 of these plates that were made.
Now I was reading around and some guys had posted saying that the MUSTANG T56 has overdriven gears for 5th and 6th thus making it pretty much kaka for higher speed. BUT the Aussi guys say that you MUST use the CAMARO T56. Is it because of what has been said about the Mustang T56 to be true ? Is it possible that other Chevy type T56's have this weird 5th and 6th ?
Quick Reply: 2JZ + Tremec T56 ?????
