92 Sc400 Crankshaft Issue
I am trying to change the water pump and timing belt. But i am at the point of taking off the crankshaft pulley bolt. I have enough tools to get it loose i just need to make the pulley hold itself in place. Now is there a way i can lock up the cams or the flywheel? And if so how would i do this properly? thank you
-Drew
-Drew
You either need to make your own tool out of steel.......if you search the forum there are alot of posts on this and some very recently posted. Or get the SST
Also during the search you will find a few threads about using your flywheel as well.........
