No voltage from pins IGT 1-6 at ecu
recently swapped a 92 soarer jzz30 automatic 1jzgte into a 95 sc300, and i cant get any fuel into the cylinder.
all of my ecu terminal values are correct except for pins IGT 1-6
pins IGT 1-6 have no voltage at the ecu with key on
i tested continuity of the wires between the ignitor and the ECU. no shorts were detected
IGF shows 5v with key on
if you go through the diagnostic troubleshooting procedure in the toyota service manual it says to replace the ignitor with the symptoms ive listed above. However, i just replaced the ignitor with a brand new one and i still have no signal to/from IGT 1-6
the repair manual suggests the ECU could be bad. Before i replace the ecu though i want to see if anyone has any suggestions to why im not getting any voltage at pins IGT 1-6
I'm not saying either is right or wrong, but here is what I am reading from the 97 diagnostics manual on Stu Hagens site. It seems to me that you should get around 0 volts when the coil is not firing because the coil is fed hot and the ECU sends the igniter a signal that grounds it to fire it right? Im not sure on the exact operation obviously.
also, you are correct the 97 2jz calls for -.1 - .5
however, thats definitly a OBDII computer for a 97 2jz. This 1jz was manufactured late 91/early 92 so it has to be OBDI. I also get absolutely NOTHING from any of the IGT terminals, so even if it was supposed to be what the 97 is calling for im not getting that either
Good point on the OBD thing. Even so, OBDI and II should be pretty much the same, since the OBDII ECU is plug and play in an OBDI car is it not?
So you are getting an open reading on the ECU pins then? Interesting. Since the 1jz ECU is famous for failed caps, I guess you could open it up and visually inspect them for leakage.
Sorry I am not more help.
im not sure if they are a direct swap, i wouldnt think so since at the very least the O2 sensors are 1wire(obd1) and 4wire(obd2)
when i probe the ecu at pins IGT1-6 > E1 there is no fluctuation in voltage whatsoever.
i have taken the ecu apart to look at the PCB and the caps, i didnt see anything burned or any caps leaking
Have you measured IGT voltages when cranking, or just with the key on? The TSRM says that during cranking, you should get >.1v but <4.5v.
I also did read that if you don't get an IGF signal, the ECU cuts injection, so as you suspected, there is a direct relation between proper spark control and the fuel injectors.
