Difference between Soarer W58 and SC300 W58?
Old 09-11-10, 09:42 PM
GT60Lex
GT60Lex's Avatar
Default Difference between Soarer W58 and SC300 W58?
My stock W58 that came with my 95 SC300 is on it's last legs and I need a replacement. I came across two trannys both are said to be W58 but the pic looks different around the shifter area. Can anyone help explain what why there is that difference, are they really both W58. Can either be used for my 95 SC300?
Here is a pic for the SC300 W58 from RGW LLC
Here is a pic of the Soarer W58
Can anyone shed some light on the differences? Thanks.
Old 09-11-10, 09:46 PM
ClearP
ClearP's Avatar
Bottom one looks like R154, soarers come factory R154 while Lexus sc300 come factory W58. Get the R154 is you can
Old 09-11-10, 10:14 PM
GT60Lex
GT60Lex's Avatar
http://en.wikipedia.org/wiki/Toyota_W_transmission
The Soarer also use the W58, I believe they are both W58 but can they be used interchangeably?
Old 09-11-10, 10:23 PM
ClearP
ClearP's Avatar
Yes, for 1986 tho
Old 09-12-10, 08:12 AM
BartleDoo
BartleDoo's Avatar
They are both W58's. One is from 92-94 and one is 95-97. The first photo is of the latter. You want that one.
Oh and search, there is plenty of info on this topic.
Old 09-12-10, 10:20 AM
kez
kez's Avatar
^^^^ bartledoo is right. Bottom one isn't a r154 just a earlier model of the w58 than the top w58
Old 09-26-10, 08:03 PM
GT60Lex
GT60Lex's Avatar
Thanks for the info BartleDoo and everyone else. It really help me to decide which one to select. Just a bit of info I found on supraforums. The later ones has steel sandwiches and the earlier ones are alloy. It's stronger I presume.
Old 09-27-10, 12:35 AM
RedPhoenix
RedPhoenix's Avatar
ALL SC/MK4 have steel sandwich plate. You can use EITHER of those transmissions above. The top one is the better choice though, but either is OK.
Old 09-27-10, 04:35 AM
Gspec
Gspec's Avatar
rebuild = less than $350.....why bother swapping it?
LexusFTW
SC400 / 300 Classifieds
06-24-13 08:33 AM
UpInTheLex
12-30-10 10:34 AM
veltall
GS - 1st Gen (1993-1997)
10-07-09 01:30 AM
94_soarer
11-01-08 03:55 PM
RedPhoenix
Suspension and Brakes
03-21-08 04:08 PM
Quick Reply: Difference between Soarer W58 and SC300 W58?
