Leak here and there...is this supose to be there?
I bought this SC300 over a year ago with 110,XXX miles now and replaced the valve cover gaskets a few months ago so there are no leaks but,now it's leaking not from the valve cover but,what we think may be coming from the cam seal maybe?And an oil leak coming from the rear under valve cover?Also we found that the harmonic balancer was replaced but,is this power steering hose suppose to go there so close to the belt?Any help or advice where leaks might be coming from.
Leak in front looking in from the distributor
Leak in the rear
Is this right/wrong??underneath view
Leak in the rear
Kinda hard to differentiate what's what.. try and back up and take some pics, and if you can, circle where it's leaking.
But if you're leaking by the distributor, it may be the distibutor o-ring.
Don't know where in the rear.. unless your valve cover is leaking again.
If you're leaking from the crank pulley, it could be your front main seal.
distributor o-ring is leaking in Number 1
Number 2the rear half-moons under the valve cover are leaking, need FIPG or equivilant for that
Number 3 could be cam seals or the front main seal. Either way, both are good signs that you need to get a new timing belt. Also get a PCV valve, yours may be clogged and causing all this, only a few bucks at any auto parts store and easy to replace. It will help prevent leaks like this from happening later on.
dubstatus
GS - 1st Gen (1993-1997)
12-07-16 07:27 PM
misomeru
Performance & Maintenance
04-28-12 08:26 AM
