98 SC400 Power steering acting wierd.
My power steering is acting wierd. Its not leaking, Its not wineing. But its starting to get really stiff @ about 3/4 way to lock. Also when im pulling out making a 90 degree turn, the wheel will not spin back on it own. Its staying turned. I have to turn i back to center. Its getting worse as each day goes on. Im thinking maybe flushing it will work, but I dont know yet. Just trying to get some ideas b4 i tear into it. Has this happened to anyone else. I hope the racks not going out or the pump.
Hasn't happen to me. Air in the system maybe? Hope a good flush works too but it might be the rack. You'll somewhat see the oil spin on the reservoir when you open the cap while the engine is running or when u pull the return hose when u do the flush.
I guess there is no problem with the power steering, NOW that the lower control arm ball joint pulled out of socket, & fell on the tire. I was 30yrds down my street when i heard a grinding sound. I stopped. Tried to back it to my drive way, as i started to back in, turning. I comes out of socket. No damage so lucky. But now I gotta get a control arm. So i get a hookup for 249 brand new supra lca. But i still call around to some local sc/surpra shops to see if they have a used one w/a good ball joint, cause i have daizen bushings already. David @ snap performance says that supra/sc lca are not EXACTLY the same. He said not enough to notice anything but ware out the bushings faster.
So now Im like WTF, $249 is a deal but if its not the same that sucks cause, got to have a alignment to get it right & what if it changes the handling of the car, cause its 1/8th inch longer.
been running these just fine for a quite a while now; alignment specs came out perfectly.
This sounds a bit hysterical if you ask me. Is he alleging that any differences are NOT within adjustment normal tolerances ??
For the record, it should be pretty much assumed that you'll need an alignment done ANY time you change your lca's. . .even to Lexus factory parts.
Hunh????
so you have these & no prob at all.
And no he didnt alledge that it wouldnt be able to be put into spec.
Well, if you've got poly's and new sleeves (inner and outer) you could always press them out and sell the rubber units on here; I'm sure someone would buy them. If you track the car, you will notice a difference between the cushiness of the rubber vs. the tautness of the poly. But remember, the rubber is bonded to the sleeves, so if you don't have replacements you'd have to burn out the brand new rubber, wasting them.
The way you have to get the stock bushing out, you pretty much have to destroy them. The big end "w/the notched bushing sleave "rear of control arm" side. Is almost saveable but the front side is not @ all. Fits just like the SC one w/the polys. Sucks it turns out to be $250.00 ball joint.
Msaucier
Performance & Maintenance
02-06-16 04:47 PM
