Anyone else have their LS400 calipers high polished??
Old 08-28-10, 03:48 PM
MIGS
MIGS's Avatar
Default Anyone else have their LS400 calipers high polished??
Today I started removing all the rsurface rust and grime with a circular wire brush attatched to my drill. cleaned the surface up pretty good. Now i'm at the stage where i want to smooth the surface/crevices of the caliper. I hit one small section with some sand paper...just to test it out..and the results were decent...but i know there's gotta be a better way to polish and get my calipers to shine like aluminum foil
And what protection can i put on the finished calipers to prevent them from accumilating rust once im done with all this?
thanks in advance for any feedback..
Old 08-28-10, 04:47 PM
Gspec
Gspec's Avatar
Aluminum doesn't rust.....it oxidizes.
Old 08-28-10, 05:30 PM
MIGS
MIGS's Avatar
yeah whatever..u know what i mean..the ugly stuff. lol
Old 08-29-10, 03:35 PM
MIGS
MIGS's Avatar
Damn 31 views, and only 1 reply...
guess no one else is doing/done this.
Old 08-29-10, 06:31 PM
fuel4blood
fuel4blood's Avatar
Just search google how to polish metal. Theres alot of threads. Basically your gonna sand the hell out of it, starting with a coarse grit and working your way up to a very fine grit. Then your gonna use some metal polish and give it a nice shine.
Old 08-31-10, 09:43 AM
LEX_MAN
LEX_MAN's Avatar
Waisting your time man.Even if you polish it ,it will take few days to oxidize again. Theres no clear coat that i know that will stick to polished surface....polished surface=smooth ,Clear coat needs rough surface to (bite)
But theres clear powder coat if you are serious about it.
Old 08-31-10, 10:28 AM
Tabaka
Tabaka's Avatar
I believe mr2tosc4 has his LS calipers polished. Send him a PM.
Old 08-31-10, 01:37 PM
Klaus
Klaus's Avatar
search for polished ls400 calipers
https://www.clublexus.com/forums/sus...alipers-2.html
BOOM page two
Old 08-31-10, 02:21 PM
SlickNick3
SlickNick3's Avatar
I used a dremel. they have a sanding kit and a polishing kit. works great to get into the crevices
Old 09-02-10, 11:22 AM
mr2tosc4
mr2tosc4's Avatar
Use 50 grit sandpaper by hand/dremel until you can move up to 100. Then let dremel take over til everything is smooth enough. move to 200, 400, 800 then 1000 wetsand to 2000 wetsand. Use the polishing kit to finish off. Upkeep - every 3-4 months use aluminum polish if you want it shiny all the time. I try to polish once a year, it doesn't get too bad. good luck
Old 09-02-10, 02:05 PM
okbobbo
okbobbo's Avatar
You could have them anodized any color you like. Anyone tried this yet?
Old 09-03-10, 02:36 PM
MIGS
MIGS's Avatar
awesome thanks..
guess i'll be doing this come saturday..
Old 09-04-10, 09:02 PM
slappy96
slappy96's Avatar
RBChroming 75 dollars per caliper...Chromed. Then it's windex and a paper towel till you're on Social Security.
Old 09-05-10, 05:54 PM
1WILLY1
1WILLY1's Avatar
those polished calipers look great....are the stock sc400 calipers the same--
i would love to do that to them...mine are covered in rust----
--im sure there is a high heat clear coat that will work fine..even if you have to clear coat them every 6 months or so it is worth it.
thanks
Old 12-21-13, 05:02 PM
Biddles
Biddles's Avatar
BOOM page two
That's pretty damn sexy... Sadly I'm still a while away from this step. Gotta get my wheels soon...
Quick Reply: Anyone else have their LS400 calipers high polished??
