SC300 2JZGTE swap - ECU problem 5k rpm cut off?
Old 07-21-10, 06:24 PM
Tylerstc
Tylerstc's Avatar
Default SC300 2JZGTE swap - ECU problem 5k rpm cut off?
Just bought a 92' SC300 with a JDM GTE swap. Originally an automatic, now has an R154 manual I believe.
It is having a problem with rpm cuting off at around 5k rpm. I think it only does it at full throttle. I was told by the previous owner that it has an auto ecu (I assume for the aristo) and that it thinks that it is in nuetral at that rpm and full throttle and that is why it is cutting off the fuel/throttle. It only started after he had a shop switch ecu's (I think from a 6 speed ecu because it wouldn't allow the climate control to work) to the auto ecu.
I was told to contact Dr. Tweak because there are 2 wires that I need to mess with...but he hasn't responded.
Any ideas?? It really sucks not being able to rev this thing out!!
Thanks!
Old 07-21-10, 08:18 PM
attzor
attzor's Avatar
First, get new plugs and gap them low, .24-.26, make sure they are the correct plugs.
Old 07-21-10, 10:34 PM
Tylerstc
Tylerstc's Avatar
Will do, but why do you suggest that? I bet with increased boost a lower gap is needed huh? I know I should just search...but what is a good plug?
Old 07-21-10, 11:17 PM
attzor
attzor's Avatar
Not sure, since it's a 2jzgte, search on SF. I know that the same thing was happening with my sc300 with a 1jz and it was because of the plugs, it also could be bad coils. It's like a spuddering right?
Old 07-21-10, 11:32 PM
Tylerstc
Tylerstc's Avatar
I was told by the previous owner it started doing that right after the auto ecu swap, and the guy (dave at snap I think) that did the build and changed the ecu's out told him that was the cause of it . I just got the car and haven't had a chance to drive it too much, but I think it only happens at full throttle. It does it in nuetral too if it's floored, so I really think it is the ecu problem. It's not really a spuddering, it just cuts off, kind of like rev limiter.
But I will look into the plugs, and I should do that anyway so thanks! This is a great site, lots of good info
Old 07-22-10, 07:56 AM
Dx3
Dx3's Avatar
NGK 3330's would be fine.
Jonny
Old 07-22-10, 08:21 AM
turbodremz
turbodremz's Avatar
I would check the wiring on the park/neutral safety switch to see how it was rigged...
Old 07-22-10, 10:22 AM
Ali SC3
Ali SC3's Avatar
yup, first thing i think of when someone says auto ecu. search for the wiring info.
murph4747
05-30-12 09:23 AM
synco357
07-19-11 06:21 AM
JesLet
11-01-10 05:40 AM
solprps92
SC- 1st Gen (1992-2000)
08-25-10 06:02 PM
DasBach
05-04-07 07:10 AM
Quick Reply: SC300 2JZGTE swap - ECU problem 5k rpm cut off?
