power steering back flow?
okay guys. i redid my power steering system cause ive been getting leaks.
i fixed the leak [o-ring under the reservoir] and then i also re routed my ps cooler. my oem lines were smashed from a prior accident.
my ps cooler is now located in front of my radiator, but below level with the tow hooks.
proper fluid levels, but when i turn off my car, i can hear air and even sometimes fluid spit out of my reservoir cap. and some times spits out plenty of fluid. never had this issue before untill i opened the system.
could there be air trapped in the ps cooler and it stays in the cooler when i turn off my car, it then pushes the fluid into the reservior, causing it to spit out?
any ideas?
any ideas?
ima guess air bubbles patrick. i hope thats it.
only thing that i changed was that o-ring under the reservoir join to the actual PS pump, and then i lightly put some RTV blue around the mating flat surface just to be sure.
other then that, the pump stayed the same. type of fluid stayed the same.
back, backflow, backflowed, backflowing, backflows, flow, fluid, fuid, power, pum, pump, reservoir, steering, steeringpump
