replacing clutch
Old 05-31-10, 04:16 PM
92sckid
92sckid's Avatar
Default replacing clutch
This is my first Lexus. Ive been driving with a horribly worn clutch for the past seven or so months. Its 92 SC 300. I was planning on selling it but figured it has more potential than anything else I can afford right now. Now the problem is that I cant find a basic flywheel anywhere. Just asking for any ideas on where I can find one and as well I could use any pointers to help replacing it. First time Im really working ona car myself. I have a couple of friends who know what there doing but everyone can take advice from more expierienced people. Thanks.
Old 05-31-10, 04:42 PM
Ali SC3
Ali SC3's Avatar
if its an oem flywheel there is a chance you can just get it resurfaced.
most transmission shops should be able to take care of that if you drop it off.
Old 05-31-10, 07:41 PM
92sckid
92sckid's Avatar
Ive been driving on it so long that its pointless. i let the clutch out and it wont stall.
Old 05-31-10, 08:45 PM
Ali SC3
Ali SC3's Avatar
your clutch is probably done. that doesn't mean there is anything wrong with your flywheel.
they are 2 different parts, usually it needs to be inspected and measured, and if its still good you can resurface it.
Old 06-01-10, 02:19 PM
topdog849
topdog849's Avatar
i just replaced my clutch last week with the help of 2 buddys, its a pretty straight foward job. where in ohio are you? pm me if you need help
Old 06-01-10, 03:26 PM
92sckid
92sckid's Avatar
Im in stow about ten minutes north of akron. I know its not that hard of a job. It will take only a day at most. I know its the original flywheel and its got 224xxx on it so im replacing it.
Old 06-01-10, 06:00 PM
Ali SC3
Ali SC3's Avatar
go oem if you can afford it. check on the price at toyota for a n/a mk4 supra, it will probably be lower than the lexus price.
Old 06-02-10, 01:03 PM
topdog849
topdog849's Avatar
i ordered my flywheel new from the dealer for about 275. beware that it doesnt come with dowell pins. i ended up reuseing the old ones. i had to take a grinder to cut the ring gear off the old flywheel and use a punch and a 3lb hammer to take out the dowel pins.
ccotenj
SC- 1st Gen (1992-2000)
17
09-05-15 09:14 AM
XplicitlyR
01-21-12 07:19 AM
wagomaniac
04-08-09 01:33 PM
93sc3005sp
17
06-05-08 03:17 PM
JspecSC3
03-25-07 08:35 PM
Quick Reply: replacing clutch
