What is this hose? (1jz)
Old 05-02-10, 10:45 AM
jinsoku3g
jinsoku3g's Avatar
Default What is this hose? (1jz)
Heard a hissing on my car today, cant find what this hooks up to, if i put my finger over the end of it the engine stalls out.. wtf?
thanks guys
Old 05-02-10, 02:13 PM
meangreen1
meangreen1's Avatar
I think it goes to the power steering. Check out the reservoir's vac lines
Old 05-02-10, 02:18 PM
jinsoku3g
jinsoku3g's Avatar
That would explain it not being hooked up, as my ps pump is no good, I hope it's not doing damage chillin like that, thank you!
Old 05-03-10, 04:38 AM
stockhatch
stockhatch's Avatar
If its hissing, it is a vacuum leak until it hits boost. Interesting that it would stall if you plug it. Is the car stock, or tuned? Does it run ok besides that, or is it rich most of the time?
Old 05-03-10, 10:29 AM
jinsoku3g
jinsoku3g's Avatar
It's stock manual 1jz ecu on the 1jz swap..it seems to run fine, like u said a vaccuum leak till it hits boost, it only seems to hiss on idle
Old 05-03-10, 12:48 PM
stockhatch
stockhatch's Avatar
If you plug it and then try to start the engine, will it start and run, or just crank over and not start at all?
IneednSC
SC- 1st Gen (1992-2000)
12
09-27-13 12:25 PM
Yahoo27
07-30-09 10:45 PM
nate579
04-21-09 03:59 PM
Tuning
02-16-08 01:20 PM
T70Soarer
02-05-07 08:34 PM
Quick Reply: What is this hose? (1jz)
