Swapping to supra trans can i get better MPG with a 5 speed instead of a 4 ?
Old 04-25-10, 08:05 PM
SC40V8
SC40V8's Avatar
Question Swapping to supra trans can i get better MPG with a 5 speed instead of a 4 ?
I have a 1993 SC400 and my trans is shifting hard when going from Park to Drive. The trans shifts perfect in all other gears.I was told to not change the trans fluid because it could cause the trans to start to slip, is this true, or is there something else i can do to make the trans not shift hard when going into drive. When i purchased the car the previous owner had bought a Toyota Supra trans and had not got around to installing it. So i have this trans problem my questions are can i do a trans flush and change the filter to solve my problems or i also was told to install a shift kit to make it shift in to drive the normal way.
Another Question i have is if i install the supra trans in my car will it improve my MPG since i will another gear to cruise in, cause at 80mph im almost at 3000 RPM and cruising at that RPM is killing my mpg on the highway since i travel to work about 30 miles a day. If i install the trans would i need any other parts to make it fit smoothly?
Let me no what u guy's think please right back other forums i have posted this on haven't replied back for about 3 weeks and i think this is a very good question to ask about gaining MPG from this SWAP.
thanks Jeremy
Old 04-25-10, 08:35 PM
SC40V8
SC40V8's Avatar
Both Trans the supra trans and the stock trans are automatic just to let anyone know
Old 04-25-10, 11:14 PM
Ali SC3
Ali SC3's Avatar
you know both the SC and supra autos are 4spd right? not going to change much.
if you want to increase your mpg/lower your rpms you can swap in a differential with a different final drive like from the GS.
Old 04-26-10, 06:23 AM
SC40V8
SC40V8's Avatar
I thought that but wasnt sure on the automatic so i guess i will swap the trans and be ok with that but now i have another problem on my hands the car doesnt want to idle right it is ruff when coming to a stop but after hitting the gas alil it will stop and idle correctly anyone have any ideas and i already read about cleaning the IACV and that helped
Old 04-26-10, 08:53 AM
SC40V8
SC40V8's Avatar
thanks was very helpful can you recomend any rear diffs that work well
emLEX
12-02-15 04:52 PM
UR2klose
07-30-09 06:42 AM
wanderer99
ES - 5th Gen (2007-2012)
44
03-17-07 07:05 PM
bublik
02-16-06 11:21 AM
Quick Reply: Swapping to supra trans can i get better MPG with a 5 speed instead of a 4 ?
