1jzgte VS 2jzgte (jdm) turbo
Old 04-24-10, 05:12 PM
frankdms
frankdms's Avatar
Default 1jzgte VS 2jzgte (jdm) turbo
Is there any difference between the *jdm 1/2j twins? Are they interchangeable? (I searched here/supraforums/google and not gotten a specific* answer) Thanks in advance.
Old 04-24-10, 06:12 PM
soarer13oy
soarer13oy's Avatar
I doubt the 1j twins are swapable with the 2j. Your probably going to have to custom somehting.
Old 04-24-10, 09:20 PM
mptjimmy
mptjimmy's Avatar
check supra forums you need to make a spacer adapter between the turbos to space them out and it all fits,
Old 04-25-10, 12:46 PM
frankdms
frankdms's Avatar
^Do they flow more hp? 1j vs 2j? Is one bigger than the other?
Old 04-27-10, 11:02 AM
Luv2xl
Luv2xl's Avatar
ct12 (1J) compared to ct20 (2J). 1J blades are ceramic and they will go bad with continuous beating. The 2J blades are steal (if not mistake) and can take the abuse. However, like everything else, it has its threshold..
In addition to the spacer, one of the manifold bolts has to be made larger to accomdate the bolt pattern. With the spacer and the larger hole, also a custom down pipe is necessary...
Old 04-27-10, 12:00 PM
FUZION
FUZION's Avatar
both jdm 1jz/2jz blades are ceramic. both will leave you with no powah if you beat them up on high boost 15+/-psi..
Old 04-27-10, 01:14 PM
Luv2xl
Luv2xl's Avatar
correct.. I was referring to USDM.. my apologies for the confusion..
for those interested..
"For the export model (America/Europe) Toyota upgraded the Supra turbo's engine (smaller, steel wheeled turbochargers, bigger fuel injectors, etc.)."
If I were you, I would go with the USDM version..
Old 04-28-10, 10:07 AM
RED95sc
RED95sc's Avatar
usdm versions are harder to find, ironic though since we are in the us, and when you do find them, people want a lot more money.....dont mean to thread jack, but i wanted to know, does anybody in here know if there is a difference between the soarer auto trans, and the sc300 auto trans internally
Old 04-28-10, 10:49 AM
hmhatch
hmhatch's Avatar
They are not that hard to find. I just picked up a set with 25k on them for $350 from supraforums.
Old 04-28-10, 11:02 AM
RED95sc
RED95sc's Avatar
oh my bad, i was talking about the usdm 2jzgte motor, not just the turbos, your right, those are not hard to find since a lotta people go single
Old 04-28-10, 12:13 PM
soarer13oy
soarer13oy's Avatar
They are pretty common to buy just more expensive. I got a set of jdms if anyones interested.....
LexLova
Performance
10-04-16 07:02 AM
cavette
05-02-09 07:54 PM
Quick Reply: 1jzgte VS 2jzgte (jdm) turbo
