Sludge Help!
Old 04-22-10, 06:00 PM
InhumaneSC
InhumaneSC's Avatar
Exclamation Sludge Help!
So my low oil light kept flashing on an off, and when I would check the oil on the car cold, the dipstick was clean as a whistle. However, when I checked it at Idle the dipstick read full or nearly full. There is no oil leak, so I took my car to my mechanic. My mechanic told me I had a terrible sludge problem and that it failed all the tests they do to see if the engine is having sludge issues. He also said it was so bad it had made it passed the O-rings? I can name engine codes off the top of my head, but when it comes to mechanical prowess i'm a total nube. He said I would probably need a new engine..does anyone else want to give an opinion either agreeing or disagreeing? Any help would be great thanks!
Old 04-22-10, 06:39 PM
Gspec
Gspec's Avatar
I'm a mechanic, and I gotta agree.....if it's sludged THAT bad, you need to be motor shopping.
Old 04-22-10, 07:47 PM
soarer13oy
soarer13oy's Avatar
can you sea foam the car to clean it up?
Old 04-22-10, 08:08 PM
StiCk3
StiCk3's Avatar
no amount of seafoam is going to fix ring blow by....
time to go shopping...maybe a GTE in your future?
Old 04-22-10, 08:27 PM
InhumaneSC
InhumaneSC's Avatar
ha a little earlier than I expected, I finally had save up just enough money to go Stance GR+ lol and this happens...
I'm going to look around for some shops in the area..and price motors hopefully go 1jz if the motor can't me saved. Just hope I can get the money together lol.
Old 04-23-10, 10:33 PM
InhumaneSC
InhumaneSC's Avatar
Lol turns out my mom scared the crap out of me, the mechanic said it was a possibility. He sent a scope through the engine and said there is absolutely no sign of sludge. He took a second look at it and replaced the fuel sender unit. This seems to have fixed the problem, as the light has not come back on. Thanks for the help guys.
Old 04-24-10, 06:18 PM
StiCk3
StiCk3's Avatar
AHHHHH!!!! the ol "mom says" problem....exact reason why i never let my mother touch my car. Last time she did she had to call a mechanic because she couldn't get the car started. $100 later, turned out she didn't put in the clutch pedal, thinking it was a "no clutch start" cars....yea right
glad things turned out ok
B2jz
IS - 1st Gen (2001-2005)
09-28-17 01:50 PM
rena
02-14-14 12:08 PM
lcc014
Maintenance
17
07-13-04 06:24 AM
nivram
Performance
05-13-04 10:40 PM
mrshabo
SC- 1st Gen (1992-2000)
06-20-03 08:23 AM
Quick Reply: Sludge Help!
