help!!! power steering issue...
Old 03-23-10, 07:53 PM
scviolence
scviolence's Avatar
Unhappy help!!! power steering issue...
car is 95 sc300, 148k, auto alright i first thought that my car maybe had a crank pulley giong bad because it was making a loud screeching noise in the mornings...but with further investigation, i've discovered that it only does it when i turn the wheels all the way left or right... this screeching noise im takling about is ridiculously loud like when it happens i want to shut my car off and act like it shut off lol...yeah its embarassing....just wondering if anyone else has had this problem and what route they took ie; swapped ps hose, rack n pinion, ps pump?? my pump isnt winding nor does it appear to be leaking anywhere, and the hose looks and feels okay....im going to check the fluid again tommorrow because it didnt start doing it until i went by a pep boys for an oil change...def not doing that again... the guy didnt know the car was mine and i was in there, and he couldnt find how much oil went back in and he said "ehh ill put 4",i then proceeded to raise the bullsh!! t flag lol...anyways any help or guidance would be appreciated thanx in advance..
-David
Old 03-23-10, 07:57 PM
Nova
Nova's Avatar
correct me if im wrong as i havent been in a sc for that long. but isnt there a p/c pump issue with these cars?
Old 03-24-10, 05:20 PM
scviolence
scviolence's Avatar
so i checked the fluid, was pretty low topped it off...car still made some noise but im thinking mayb it has bubbles in the sytem...the thing that concerns me most is sometimes it does it without turning soo i will see over the next day or two...
Old 03-24-10, 05:32 PM
Nova
Nova's Avatar
if u think there is air in the system turn the car on and turn the wheel lock to lock a few times then hold the rpms at ~2000 and go lock to lock a few more times
Old 03-24-10, 06:22 PM
scviolence
scviolence's Avatar
^^^^ will be doing this tommorrow tanx for the advice brother..
Old 03-24-10, 06:47 PM
Nova
Nova's Avatar
no worries let us know how it turns out.
Old 03-25-10, 04:32 PM
scviolence
scviolence's Avatar
Angry
tried locking side to side or about 15 minutes....and im gonna be honest right now...i want to blow my car up right now....IM SICK Of this noise...it keeps coming on randomly!!! today it did it like 3 times ...i would stop at a light....light turns green driving straight and it sounds like freddy kruger is under my damn hood with 40 chalk boards...only for like 5 super embarressing seconds(long enough to look at my car and go ummm WTF) ...im at the wtf point right now...somone please help...
Old 03-25-10, 04:43 PM
abounly
abounly's Avatar
flush your PS
Old 03-25-10, 06:29 PM
scviolence
scviolence's Avatar
im gonna try flushing it this weekend at the hobby shop hopefully ill come back with some good news...i just wish i knew wtf happened...i really want to go back to pep boys and eff that guy up that changed my oil and "checked my fluids"...im gonna pray for my car tonight cause im sick of this problem lol....(cant you tell lol)
Old 03-25-10, 06:36 PM
abounly
abounly's Avatar
Thats why you do all the work yourself. Either that or go to a TRUSTED mechanic shop every other shop "mechanic" doesn't give a jack about your car plus they are inexperienced. i had a horrible squeel/creak/screech/sound when i turn or took a sharp turn, not only the sound but my steering wheel will fight back . After the flush the car felt totally different i took hard turns fast uturns no sound no nothing.
Week later i heard a small screeching sound coming from the front and i just topped the PS off and it went away
Best 15$ i ever spent! All you need is 2 quarts of Mobil 1 synthetic ATF
It is pretty simple to do it would be a lot easier with 2 people. I was able to do mine in less than 30 minutes most of the time just slacking off and talking with my buddie.
Old 03-25-10, 07:28 PM
scviolence
scviolence's Avatar
yeah i dont know wtf i was thinking lol i always do my own maintenance and for some reason i was like ehhh screw it...lol....problem ever since....well its official im not paying for any kind of maintenance anymore...
Old 03-26-10, 12:37 AM
abounly
abounly's Avatar
http://my.is/forums/f67/is300-power-...-flush-340996/
it is the same exact thing.
Old 03-28-10, 07:14 PM
scviolence
scviolence's Avatar
so did the power steering flush no bubble or anything....wasnt that hard....still have screaming noise.....this time i actually went up to the front of my car and watched the drivebelt and gave it some throttle...when it made the noise my drive belt went back and forth pretty rapidly on the drive belt tensioner pulley......im starting to think this is an issue with the crank pulley...cause when it stopped making the noise and i gave it throttle the belt didnt move back in forth all eratically....
Old 04-06-10, 11:45 PM
ProjectSC3
ProjectSC3's Avatar
I would remove the belt and check all the pulleys by hand to make sure the bearings feel good. I would also check the belt tensioner to make sure its putting the proper tension on the belt.
When i had a problem with my crank pulley it squeeled non stop one morning (which i ignored) and about 5 miles later there was a loud bang and i just saw the outer ring of my crank pully in my rear view mirror. Now i never ignore any unusal noises. Lesson learned.
Old 04-07-10, 12:07 AM
soarer13oy
soarer13oy's Avatar
hope the crank pulley solves your problem.
norakat
ES - 6th Gen (2013-2018)
09-28-20 04:51 AM
Countman55
IS - 1st Gen (2001-2005)
08-12-18 08:03 PM
gs300by
01-06-16 05:24 PM
Holger
12
06-10-13 01:03 PM
RooLex
GS - 1st Gen (1993-1997)
04-05-03 07:45 AM
Quick Reply: help!!! power steering issue...
