Random shut off?
Old 03-17-10, 01:49 PM
attzor
attzor's Avatar
Default Random shut off?
I was driving home in my SC, which is a 1jz swapped car, and the car just died, it made a depressurizing noise and just turned off. I tried to start it, and it just cranked, then 3 minutes later after getting out and checking the engine, and seeing nothing wrong, I tried to crank it and it just turned over like normal. Also, when I started it to warm it up before this, it was idling at like 2k rpm, so I turned it off, and restarted it and it was perfectly normal. It also ran fine when I was driving it.
Any Ideas? I'm changing my valve cover gasket today, but I doubt a leaky valve cover gasket would cause this. I'm going to guess it's a dieing 1jz ecu...
Old 03-18-10, 01:52 PM
BigManne
BigManne's Avatar
boost leak maybe
Old 03-19-10, 03:35 PM
attzor
attzor's Avatar
Originally Posted by BigManne
boost leak maybe
Would that cause the car to turn all the way off?
Old 03-20-10, 02:31 PM
BigManne
BigManne's Avatar
did all the electronic stuff cut off too or just the engine?
Old 03-20-10, 04:37 PM
attzor
attzor's Avatar
Just the engine, I drove it for about an hour today and nothing happened, it was fine, but now the temperature gauge isnt working? The car ran great today, barely smoked, I retightened all of the bolts around the valve cover gasket, I think that cleared up the issue with alot of the smoke. Anyone know why my temp gauge is out?
xspsi6
02-19-13 06:42 PM
BigGreen
08-03-10 03:45 PM
z0rs
03-28-10 12:35 PM
Monkiee
08-16-09 02:20 PM
FormosaSC
07-01-08 12:48 PM
Quick Reply: Random shut off?
