Motor Oil Choice for High Horsepower JZ Turbo SC
Old 02-24-10, 08:42 AM
jonboyb
jonboyb's Avatar
Default Motor Oil Choice for High Horsepower JZ Turbo SC
My SC300 (1.5JZ with PTE76) came from deep south Florida and the previous owner ran the Valvoline VR1 racing oil in 20w-50. Now that it is in a milder climate in Atlanta, should I look to change the weight. I know I've always run Mobil1 10w-30 synthetic in my Supra and Starion and Mobil 5w-20 in the HHR....but I do like the increased zinc additive in the VR1.
Old 02-24-10, 09:41 AM
LSEGHATCH
LSEGHATCH's Avatar
I run Mobil 1 0w-40 or 30 can't remember
Old 02-24-10, 11:35 AM
spdrcr771
spdrcr771's Avatar
Man ive been running amsoil for acouple of years now and i think its awesome, w/there oil filter too, check it out. www.amsoil.com
you can signup for $20 a year to have a perferred customer account,and get everthing a wholesale cost. im not turbo. im n/a vvt-i 400, but i run there signature series 0w-30 racing oil. love it, im 15000mi oil change you should see what it looks like after 10000, im amazed just barley mid brown, real clean & still feels new to the touch. there the only motor oil co that warrantys motor if there oil fails.
Old 02-24-10, 11:39 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
What about Royal Purple? I have been seeing this all over the place now, for just about every type of fluid now. Any good or bad about this type?
Old 02-24-10, 12:12 PM
spdrcr771
spdrcr771's Avatar
I put that in my rear TT LSD diff, just cause thats all i could get on a sunday @ auto zone, my lexus tech that is a big time supra guy, says it sucks & to change it asap.
Old 02-24-10, 12:29 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I wonder why he says it sucks. I havent done alot of research on it, or compared to Amsoil, but I figured for that price per quart it had to be good.
Old 02-24-10, 01:02 PM
LSEGHATCH
LSEGHATCH's Avatar
I've heard mixed reviews also about Royal Purple
Old 02-24-10, 01:44 PM
Wicked SC
Wicked SC's Avatar
I use good old Castrol GTX 10w-40 with OEM Oil filter....
Old 02-24-10, 02:06 PM
JohnEd
JohnEd's Avatar
Do your home work! All the syn isn't created equal. There are some comp studies that goover all the oils from top to bottom. Amsoil was close to the top in expense. It was also not the top in performance...but came in third out of 50 nor so so it ain't much of a slouch. I would be happy with Amsoil as a complete product line. I think Toy auto trans is full synthetic but there are additives...be sure.
Engine, trans, and diff switch to syn can be poroven on the dyno AND the temp drops in all three cause Sys rfuns cooler cause it is way more slipery.
Do GOOGLE!
Old 02-24-10, 02:27 PM
turbodremz
turbodremz's Avatar
I have been using Royal Purple for years and its excellent..Used it in everything from my z31, mk1 MR2SC, to all 5 of my s13's, K5 Blazer, etc ..this includes oil, trans, and diff fluids, and have zero complaints and never had an issue.
Royal Purple used to be blended with Molybdenum Disulfide, until scar tests were done for comparison to Amsoil/Castrol/Mobil1 and RP came in 4th place with a .852 compared to Amsoil's 1st place with only a .432. However, RP has redesigned their blend since 2005 when the scar tests were done and have removed the Moly synthetic and in a scar test done in 07, they beat Amsoil with a .422 4 ball scar test while the Amsoil retained the .432.
There is nothing wrong with RP, and most of the negative rap was due to the Moly blend that was used 5 yrs ago, which has since then been removed and improved.
Castrol and Mobile1 synthetics have always been right behind Amsoil and before the RP reformulation, beat it out on scar tests until '07.
My Choice top to bottom:
1. RP
2. Amsoil
3. Castrol
4 Mobile 1
Old 02-24-10, 02:40 PM
RjBLayz
RjBLayz's Avatar
+1 Castrol GTX 10w-40
Old 02-24-10, 03:17 PM
Carfreak70
Carfreak70's Avatar
Mobile 1 5W30.
Old 02-24-10, 07:02 PM
Devo83
Devo83's Avatar
At least in my bike, I hear it's highly overrated, so I'm assuming the same for cars.
Old 02-24-10, 10:31 PM
SEXY 400
SEXY 400's Avatar
1. RP
2. Amsoil
3. Castrol
4 Mobile 1
NICE thats EXACTLY how I'd choose it too.
Old 02-25-10, 07:10 PM
Devo83
Devo83's Avatar
Good to know
Quick Reply: Motor Oil Choice for High Horsepower JZ Turbo SC
