maf replaced but new problem.
Old 12-30-09, 12:35 AM
grindin8o8
grindin8o8's Avatar
Default maf replaced but new problem.
so i was throwing a maf code which was 25 and i replaced it with a new used one. code went away but now my car idles at 1500 rpm on cold start ups in park, and 1000 rpm in drive/reverse. any idea what could be wrong?
and i also notice some smoke coming out from the intake engine area. couldn't really tell where though??? any help? and my coolant light has been coming on??? help please
Old 12-30-09, 08:05 PM
BostonSC4
BostonSC4's Avatar
the smoke is most likely coolant burning. so i assume you have a coolant leak. its probably the radiator leaking, of a hose spewing coolant. if you look at your engine bay with the engine off and such, do you see like dried spots and splatter marks? that would be dried coolant. as for the idle oddities, i'm not sure why its doing that.
Old 12-30-09, 09:32 PM
grindin8o8
grindin8o8's Avatar
could be because the smoke is not consistent. its only visible sometimes.
Old 12-31-09, 07:04 AM
lexdud
lexdud's Avatar
Is the smoke ... smoke or could it be water vapor? If the car has been sitting for a while the vapor is normal.
Old 01-01-10, 11:23 PM
grindin8o8
grindin8o8's Avatar
hmm might be water vapor. it was sitting for awhile. btw i just noticed today that when i start up the car(cold start up) the car idles at 1500 in park and 1000 in gear. when in park at 1500 the needle goes up slowly and down slowly from 1500-1700 rpm continuously. it's pretty weird but does anyone know what this could be?? when the car is warm it idles fine and sometimes very low at like 500 rpm in gear. any help please.
another problem, i've been losing coolant and today i noticed by the coolant cap(the cap where you put in coolant) there is a hose connected to it and at the other end it is just left open. so coolant can come out of it. is it normal?? ill try to get pics tomorow.
Old 01-02-10, 01:47 AM
fliptrix
fliptrix's Avatar
check your IACV, it could be getting stuck and might need cleaning, it's possible that it could be causing that looping from 1500 to 1700rpms.
Old 01-02-10, 01:53 AM
willhickey
willhickey's Avatar
yeah its normal that hose is there so if you overfill it it has somewhere to spill out once you out the cap back on
Old 01-02-10, 12:18 PM
prolifik22
prolifik22's Avatar
check the tps cause mine was doin the same thing and a member of the forum checked it out and set it and now it idles at the right rpm.....
also how did u check the codes?
Toastt
12-04-11 07:01 PM
intrinsic
04-23-09 04:36 AM
Lexus082
11-27-07 01:31 PM
ahacme
06-24-07 08:33 AM
cambo
11-24-06 01:42 PM
Quick Reply: maf replaced but new problem.
