W58 and 1jz
Old 10-21-09, 05:17 PM
veltall
veltall's Avatar
Default W58 and 1jz
Anyone on here running a w58 with their 1jz? Just wondering how it holds up to it? i've heard goods and bads of this combination but obviously looking for mor opinions. what's the most power anyone has seen one hold?
Old 10-21-09, 06:49 PM
attzor
attzor's Avatar
the previous owner of my car made 466whp on a mustang dyno, I brought the boost down to ~16-18 lbs and run pump so its probably about 400hp. And I run that daily but don't beat it bad.
Old 10-21-09, 06:54 PM
94_soarer
94_soarer's Avatar
there are a few members on here that run the 1jzgte with a w58 combo even the 2jzgte with the w58...its all about how u treat ur tranny jus dont beat on it too bad..with a good clutch a w58 could hold around 400tq...but if ur banging gears every other light then u will pop the clutch then blow the tranny aswell.
i will be running a 1jz with my w58
if u ask me i say the w58
Old 10-21-09, 07:00 PM
LSEGHATCH
LSEGHATCH's Avatar
w58 with around 400hp here. Daily driven before and didn't beat on it, no clutch kicking!
Old 10-21-09, 07:15 PM
SH_JZZ30
SH_JZZ30's Avatar
I have a mk4 supra w58 on my 1jz. I'm running about 14 or 15psi on stock twins. I daily it and sometimes clutch kick. I havent dyno'd so I'm not sure how much power I'm making. I've done some hard driving on it and it's holding up very nicely. I also have an upgraded clutch. I've heard from some local people that the mk4 w58 is supposedly the strongest of the w58 but I don't how true that is.
Old 10-21-09, 07:18 PM
veltall
veltall's Avatar
soo like lets say for instance...drifting?
Old 10-21-09, 07:25 PM
94_soarer
94_soarer's Avatar
Really i thought u was running a R154 with ur setup bro...dang guess again..lol
what type of clutch do u have..i got a centerforce dual friction clutch i wonder how its gonna hold up when i boost...
W58+Drifting=FAIL
Old 10-21-09, 08:19 PM
99SC42
gte & na-t
99SC42's Avatar
1JZ W58 soon to be R154 i love Tranny but hate the Clutch, Cheap$$$ Spec Clutch stage 2+ it's garbage , make sure you don't buy spec!!!!
Old 10-21-09, 09:51 PM
veltall
veltall's Avatar
i will see how it holds up once this motor is put back together. just lookin' to see what ppl on here are saying about the w58s.
Old 10-22-09, 09:36 AM
96sc300
96sc300's Avatar
The w58 will do the job up. I ran the w58 for a while and my car was stock twins. Syncro started going bad so I bit the bullet and got the Soarer R154 and haven't looked back. Worth the money and not have to worry about the issue.
W58 and drifting bad idea!
Old 10-22-09, 11:01 AM
Biggu
Biggu's Avatar
W58+Drifting=FAIL
ive been drifting with my w58 for 2 years now and its just fine. id all depends on how you treat your car and how you shift. on the street i granny shift. on the track i still granny shift except i clutch kick alot more. btw im also at 380 hp on my 1jz with the w58 and its fine. learn how to drive and it will be just fine.
Old 10-22-09, 11:30 AM
veltall
veltall's Avatar
that is definitely reassuring. i dont drive crazy or anything on the streets either but track time is nothing but clutch kicking.
Old 10-22-09, 12:07 PM
Ali SC3
Ali SC3's Avatar
try not to go too aggressive on your pressure plate, with clutch kicking it will amplify the wear onto the tranny. I got the act 6 puck sprung with xtreme pressure plate and it is pretty beefy, if I had to do it again for a more streetable setup I would try one grade lower pressure plate. mostly everyone who tries to drive it stalls out. just takes some practice though, I have no problems moving the car just inches in heavy traffic. holds boost like a whoa..
jmanhas
05-05-14 01:23 AM
sayayin
SC- 1st Gen (1992-2000)
04-08-11 05:46 PM
bullfrogg0
General Classifieds
09-13-10 04:48 AM
Quick Reply: W58 and 1jz
