Car putts,radio turns off when I hit turn signal?
It's happened a few times before then stopped for a couple months and now started again today on the HWY...when I hit my turn signal the radio turned off and the car shook a little like there is bad ground or something is being drawn out?..is this common on a 93 or earlier??..any input on where to look??..
Thanks
Thanks
I cleaned and sanded the terminals today and checked the grounds...seem all good...with the stereo wiring are you talking about behind the head unit?..it came with a 7"DD but,the previous owner had took the sub/amp out...the wire he left is disconnected from the battery...I noticed today the driver side door light is flashing like a strobe light now...i shook the car thinking it's a loose wire but,no luck...I hope it's not the alt.cause I do have a valve cover leak I haven't gotten around to fix yet..
Yeah sad to say...I talked to my friend who installs stereos and he said the same..."your not getting a constant 12v to your radio bro,that's why your ***** keeps re-programing when you turn your car off"...could be spliced in the turn signals..I hope not though,seriously how stupid can you be?...but,it has occurred on the hwy when I hit the turn signal(radio turns off,dash lights dim,headlights flicker randomly even when turn sig.is off)...but,overall if that was the case wouldn't that be the cause of a loose ground or wire somewhere??..could a loose wire in the head unit cause all this to happen randomly though??
csum7913
RX - 1st Gen (1999-2003)
06-20-17 02:50 PM
