BFI versus Injen cold intake
Old 09-13-09, 10:36 AM
tmh43
tmh43's Avatar
Default BFI versus Injen cold intake
I've got a stock 96 SC300 and want to upgrade some things. Its my dd. Am looking for a few opinions since I'm torn between building the BFI modification using stock airbox or removing stock air intake and installing an Injen air intake.
Old 09-13-09, 10:39 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Even with a BFI you are still pushing through a rippled tube. A smooth flow no turbulence CAI will always win unless you are setting the filter over the exhaust.
Old 09-13-09, 11:24 AM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
the intake tube of the Injen is metal...and that could heat up after 10 or so minutes of driving. Resulting in you sucking hot air into the engine
Old 09-13-09, 11:41 AM
2jz-sc
2jz-sc's Avatar
stick with stock just buy a k&n drop in filter
Old 09-13-09, 11:55 AM
2turbo1sup
2turbo1sup's Avatar
Intake systems for these cars dont really do much except make noise. As mentioned above, a drop-in K&N would be better
Old 09-13-09, 12:16 PM
2jz-sc
2jz-sc's Avatar
Do the drop in and modify the air box.Just some advise from the new guy!
Old 09-13-09, 12:31 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
The injen is like the SRT which is made of a different type of material that resists heat containment by quickly dissipating heat, as well it is designed to reduce turbulence. That's why porting and polishing heads works so well, reduce drag and turbulence, increase power.
Old 09-13-09, 12:50 PM
Lexscme
Lexscme's Avatar
i say drop in filters but... on the other hand and SAI is good too just for flow unlike stock intake tube with all the restictions.
choose what you wanna do,stock is good for sleeper look???
Old 09-13-09, 01:00 PM
2jz-sc
2jz-sc's Avatar
I made mine from left over intercooler pipe and stuck a k&n cone filter in the factory air box to get fresh air insted of hot engine bay heat!I will post a picture of how it looks when I get home.
Old 09-13-09, 02:57 PM
2jz-sc
2jz-sc's Avatar
here is a pic of mine
Old 09-13-09, 03:56 PM
t70 supra
t70 supra's Avatar
apexi is the best
http://www.mkiv.com/techarticles/filters_test/2/
Old 09-13-09, 04:17 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
What the heck happened?
Old 09-13-09, 04:28 PM
ThomasGS4
ThomasGS4's Avatar
dude your car looks f@#$%^
Old 09-13-09, 05:11 PM
2jz-sc
2jz-sc's Avatar
My car is ****ed I lent it to my roommate so he could go to walmart and as he was cutting across the parking lot he hit a concrete pole
Old 09-13-09, 05:18 PM
bangdangvn
bangdangvn's Avatar
WTF?!
Quick Reply: BFI versus Injen cold intake
