Clutch creaking when pressing in?
Old 08-19-09, 06:15 PM
jefferino
jefferino's Avatar
Default Clutch creaking when pressing in?
Okay this may sound stupid but I am trying to figure out why whenever I push in my clutch pedal that it sounds like an old rocking chair. It is a w58 mated to a 1jz and a Stage 3 Competition Engineering Clutch and brand new slave cylinder. Also, when driving slow you can hear chirping coming out of it which I am pretty sure is just the stupid throwout bearing needing to be soaked in some lithium grease or something.
I am just trying to figure out if it is as easy as spraying the pedal assembly with some wd40 or what? Also the chirping...throwout bearing? Any help would be great!
Thanks in advance....
Old 08-19-09, 10:14 PM
OneJay
OneJay's Avatar
Mine does that too. I think there was another thread with 15+ members all saying theirs did it as well. I guess it's just an SC thing. It doesn't do it all the time though. At least on mine. Sometimes its worse and sometimes its hardly noticeable.
I also have the throwout bearing chirping too.
Old 08-19-09, 10:50 PM
BostonSC4
BostonSC4's Avatar
my dads old BMW 328is did this so bad. his was like, when i say bad i mean bad it was as loud as the radio. but i remember it would go away when the car was cold. for example cold start and once it warmed up here comes the old rocking chair.
Old 08-19-09, 11:35 PM
SH_JZZ30
SH_JZZ30's Avatar
Yes mine does that exact same thing too. I have a 1jz with mk4 supra w58 with an ACT clutch. It's not coming from inside the car.
Old 08-20-09, 06:30 AM
aka paco
aka paco's Avatar
lol glad to know i'm not alone on this..
my clutch pedal has the creaking old rocking chair sound sometimes when i push it in as well..
i also have some throw out bearing chirping from time to time which sucks cause i just did the clutch and TB 8 months ago and probably put less then 4,000 miles on it since then.
Old 08-20-09, 07:30 AM
jefferino
jefferino's Avatar
Yea, someone on SF said that they think it is something to do with the pressure plate. Others have used lithium grease and been fine. Its just annoying to have the car look and sound so good but have that stupid noises. I think over the winter I will drop the trans again and see what I can find. I have been dealing with it since putting in the new clutch. I absolutely LOVE the clutch engagement and pedal feel so if it is something I have to deal with then I guess I need to turn my radio up louder or just run open downpipe to not hear it LOL
Old 08-20-09, 12:48 PM
99SC42
gte & na-t
99SC42's Avatar
Mine makes a stupid noise everytime i release the clutch, usually when am taking off
Old 08-20-09, 01:30 PM
jefferino
jefferino's Avatar
Omar that is because you drive like a maniac :-)
I have received some great input from SF and the concensius is this...
1. Lubricate the spring on the pedal with lithium grease (for creaking)
2. Pull back dust boot and lubricate the clutch fork pivot point (for chirping)
I'll let you all know what happens
Old 08-21-09, 11:33 AM
sc250tt
sc250tt's Avatar
my clutch also sounds like a bird but only when i let off tho. Im hoping its my T O bearing. Im on my second r154 so every little clutch/ tranny noise gets me paranoid.
Old 08-21-09, 07:25 PM
soarer479
soarer479's Avatar
if its a competition clutch there is a good chance the sound is the springs on the pressure plate bending and will soon cause engagement problems those competition clutches are worth their weight in dirt
Old 08-22-09, 02:29 PM
roxanne
roxanne's Avatar
I feel like I've seen a few "squeaking clutch pedal" threads, and still no one really knows how to permanently solve the issue. I changed my clutch and had moving piece soaked in lithium grease...still squeaks...
Old 08-22-09, 06:21 PM
ashtray
ashtray's Avatar
it comes and goes on mine..believe it or not today was really noticable lol. other days its not even there.
Studiogeek
01-30-16 08:58 AM
omarmest
IS - 1st Gen (2001-2005)
11-30-13 06:36 AM
snook
SC- 1st Gen (1992-2000)
28
11-26-09 09:03 PM
JspecSC3
03-25-07 08:35 PM
Quick Reply: Clutch creaking when pressing in?
