Trouble removing P/S pump
Old 08-08-09, 04:51 PM
jeff w
jeff w's Avatar
Default Trouble removing P/S pump
94 sc400. First time doing a p/s pump. I'm to the point of trying to loosen/remove the pump pulley and am having trouble. What have you guys used to keep the pulley from spinning so you can get enough torque on the nut? I've been unsuccessful so far. Don't have an air compressor, so an air impact wrench is not an option.
Also, best way to get the high pressure hose disconnected from the pump?
Anyone near Roseville, CA willing to lend a hand?
TIA
Jeff
Old 08-10-09, 10:05 PM
RyanV
RyanV's Avatar
If you have the pump out of the car you can hold the pulley in a vise. The nut doesn't have much torque.
You'll need 2 big wrenches. I forget the sizes but I think 19mm and 17mm for the hose
good luck.
Old 08-11-09, 12:38 PM
PERRYinLA
PERRYinLA's Avatar
Here's the best write-up I've ever seen on the SC4 PS pump and alternator:
http://hoshiko.jc-coleman.com/howto/...roduction.html
jeanD1010
01-17-18 02:34 PM
JohnEd
02-06-08 01:25 PM
VQT
10-21-01 10:32 AM
Quick Reply: Trouble removing P/S pump
