need VAF or not? when using AEM ems
hey supz.... working on sc300 and still curious if VAF have to be use if i were to usse AEM ems 1101 . will the program let you remove that or it have ot be connected.... what i'm doing is boosting the GE with a t70 turbo.
also we ended having a little problem, when we put the turbo on, its a tad bit tight as the dist. cap is in the way....1/4inch, he bought his manifold on ebay, as i believe 1 out of 10 manifold, it will not be weld perfect.
also did anyone have a simiular set up that he doing?
t4/t70 turbo,
40mm wastegate
650cc RC injector
aem ems
fuel pump upgrade
if so.. can anyone provide picture and spec... thankz
t4/t70 turbo,
40mm wastegate
650cc RC injector
aem ems
fuel pump upgrade
92+ here is a link on club na-t telling about the setup and no problem
http://forum.clubna-t.com/showthread.php?t=4921
Lanceezy
Performance & Maintenance
10-14-09 09:46 AM
