Engine won't fire up after engine shampoo
Old 07-15-09, 02:03 PM
92_1uz
92_1uz's Avatar
Default Engine won't fire up after engine shampoo
Car is a 92 SC400
I had a leaky PS hose, which I fixed today. It left PS fluid everywhere so I decided to do a quick engine shampoo, sprayed some degreaser and rinsed off with clean water. I didn't have the water under pressure or anything.
I let it dry for about half an hour, started the car, and it started up fine and idled.
I went inside for lunch, and went back out another 30 mins later, tried starting, but it wouldn't fire up. It just cranks, but doesn't fire.
Pulled the intake off, checked for water in the intake, was dry.
I've only had the car a couple of weeks, and i'm quite mechanically inclined but I'm a noob with this motor, i'm a nissan guy. Where is the 2nd coil? (i know there's one in the middle of the engine) And where are the 2 ignitors? Also how do I properly check for spark and fuel on this motor?
Old 07-15-09, 02:29 PM
QwkSC
QwkSC's Avatar
second coil is on the drivers side on the side of the block
Old 07-15-09, 03:01 PM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
As with most other people who have washed their engines you probably got water in your spark plug locations. Sorry for my poor vocab, I don't know the proper name of that place, wherever the spark plugs are located.
Old 07-15-09, 03:22 PM
92_1uz
92_1uz's Avatar
I found them right after I posted this, lol.
Well... I undid the negative battery cable, and started looking at all the connectors for the coils, ignitors, looked at the wires, and i blew any water off them with compressed air. Hooked the battery cable back up. And she fired right up
Old 07-15-09, 04:37 PM
BAD954BOI
BAD954BOI's Avatar
hope you learned a lesson...lol...
Old 07-15-09, 06:53 PM
ThomasGS4
ThomasGS4's Avatar
this didn't need to be moved. The issue was already resolved.
siknezz408
GS - 1st Gen (1993-1997)
29
06-22-17 02:04 PM
Karwan
17
11-04-12 08:53 PM
chestman88
10-29-11 11:29 PM
hb55047
NELOC
27
10-24-07 11:32 PM
buggsc3
Automotive Care & Detailing
15
04-27-05 09:16 PM
Quick Reply: Engine won't fire up after engine shampoo
