Fuel Evap Hose
Old 07-12-09, 02:40 PM
Yahoo27
Yahoo27's Avatar
Default Fuel Evap Hose
I know this hose goes into a evap canister thingy on my 300 but on my 1jz swapped 400 it's out in the open, should it be plugged or does it go somewhere? You can smell fuel out of it
Old 07-12-09, 06:54 PM
SHOLEXMAN
SHOLEXMAN's Avatar
As long as it doesn't effect the engine performance which I think it doesn't you shouldn't really have a issue. For the smell you can get a charcoal canister from the junkyard and set it up in there. Just make a bracket of some kind and bolt it up to that threaded hole on the right fender. If you running a open down pipe if you haven't finished the exhaust keep that hose away the gas will ignite. You can try a breather filter like for valve cover gases ,but I don't know how much that will help.
mhussien32
03-24-18 02:36 PM
akafixture
06-25-16 04:10 PM
hfsdude007
02-07-13 06:12 AM
93trappin
12-02-10 12:10 PM
1of120
01-10-10 03:30 PM
Quick Reply: Fuel Evap Hose
