transmission upgrade ?s
Old 06-07-09, 02:39 PM
ahmedsaleh
ahmedsaleh's Avatar
Default transmission upgrade ?s
ok i have an sc300 with 1jz swap and im using the stock w58 that was with the car. i recently blew it up im making over 400hp. trans had over 210k on it.
my question is do i swap same trans in. i only do highway pulls.
do i go r154 if so do i need to get new clutch and flywheel. if so why.
or what other cheap options do i have
Online: Report Post Edit/Delete Message
Old 06-07-09, 03:24 PM
TLDriver
TLDriver's Avatar
Yes, and because wont fit the r154... search and there will be a few good post about why and why not.
Old 06-07-09, 03:44 PM
ahmedsaleh
ahmedsaleh's Avatar
guess ill just put another w58 in it.
i know supras came with it can u use those are they stronger.
Old 06-07-09, 04:16 PM
StiCk3
StiCk3's Avatar
The MKIV W58 supras are exactly the same as the ones in the 95-97 SC300 5-speeds, same construction, same weaknesses. 400hp is usually their limit.
R154 can take your 400hp without many issues. Do a search on what you need for an R154. Off the top of my head you need a new flywheel, clutch, driveshaft, and rear end. More might be needed, im not sure.
Old 06-07-09, 04:17 PM
ahmedsaleh
ahmedsaleh's Avatar
i have a 92 sc300
VileFCboy
04-22-12 12:28 PM
Confusion
SC- 1st Gen (1992-2000)
15
12-25-10 08:30 PM
TRDmike
SC400 / 300 Classifieds
04-23-10 09:44 PM
veltall
GS - 1st Gen (1993-1997)
10-07-09 01:30 AM
Quick Reply: transmission upgrade ?s
