which driveshaft or am i stupid?
Old 05-31-09, 01:45 AM
jdmJZA70
jdmJZA70's Avatar
Default which driveshaft or am i stupid?
well i just got done pulling my old clunky ge motor (auto trans) out of my 97 sc300. after removal i placed it in my garage next to my donor aristo 2jzgte motor (also auto trans) and i noticed that the the part of the trans that connects to the driveshaft (input shaft/trans tailshaft? dont know what its called) looks completely diff...i was under the impression that i could just re-use my factory driveshaft if i have an aristo motor but it seem like that will not be possible. am i completley incompetent or do i need to specific driveshaft. i.e. mk3, sc4, etc, i tried searching but i failed miserably at that also
let me know guys, thanks!
-zeeshaun
Old 05-31-09, 08:46 AM
RyanV
RyanV's Avatar
The 2JZGTE uses a different bolt type flange at the trans output shaft. I'm not sure what'd you'd do if your swap didn't come with this flange.
You could search Supraforums for a donor driveshaft or have a driveshaft custom built.
Old 06-03-09, 07:57 AM
jdmJZA70
jdmJZA70's Avatar
does anyone know what driveshaft to use with a 97 auto sc300 when swapping in an aristo motor? i really want to avoid going custom...
Old 06-03-09, 12:36 PM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
SC400 driveshaft. You'll also need the flange i believe.
Old 06-03-09, 04:56 PM
jdmJZA70
jdmJZA70's Avatar
i thought the sc400 driveshaft is used only when you go 6 speed, im trying to stick with the aristo tt trans for now, i could be wrong though, can anyone verify the above statement for me?
chizz95
08-10-13 09:04 AM
IS300SS
SC- 1st Gen (1992-2000)
07-13-10 06:33 PM
stealth_IS
IS - 1st Gen (2001-2005)
06-28-09 08:28 PM
chrisn1978
08-25-08 10:19 AM
jzz3
03-21-07 08:24 PM
Quick Reply: which driveshaft or am i stupid?
