Fuel pump problem on '92 SC400
I shut off my car this morning at work. Left the windows down to listen to music. I got off work and went to start it and all it would do is crank over. I pulled off a fuel line and cranked it and had no fuel spitting out. I checked voltage at the fuel pump connector and had 0V.
I came on here and researched and found a couple people had problems with the FP ECU. I ran a jumper wire from +B to Fp in the diag. connector. The car still wouldnt start but I had voltage to the pump.
I'm thinking maybe the pump and pump ECU went out together. I ordered a new pump today. The car is 17 years old with 107K miles so a new pump won't hurt it. I will read into the FP ECU bypass mod. Do you think I could be having any other problems as to why it won't start? Thanks!
-Drew
-Drew
mrmcd982
SC- 1st Gen (1992-2000)
08-17-15 09:24 AM
sicwhip
Performance & Maintenance
04-25-13 05:23 AM
