Battery discharge warning lights up at low rmps
My battery discharge light started lighting up yesterday at low rmps - when I'm slowing down or at a complete stop. I feel like it must be my alternator going out. I do have a couple of subs and an amp, but I changed by battery about 2-3 years ago. What do you guys think?
If it is the alternator, then does anyone know a good link showing the proper why to change it? I've never done it before. thanks
don't buy vital engine parts from ebay. you'll be glad you didn't. Alternator is not hard to do I just did mine yesterday.
Also, check your distributer and see if you have any oil coming out of the base. A common problem is for the distributer o-ring to leak oil down onto the alternator and gum it up. If you're leaking oil from the distributer pick up the o-ring too. It's cheap and it'll save u $ in the long run.
If the core is that big a deal take it off in the parking lot of the auto parts store. I didn't do that yesterday because i had a spare set of wheels but i have done it before. just bring some jack stands because you do have to get at it from the underside.
Also, doing this lets you get it tested before buying a new one.
1. remove belt using 14mm wrench on the tensioner pulley and remove wiring from alternator. the plug in the back may be easier to get to after you remove the alternator from its supports.
2. remove 14mm bolt at top of alternator. it may make it easier to do this if you remove the air box but i have a short ram so wasn't a prob
3. remove under engine splash guard and remove 14mm bolt on bottom of alternator (there is also a line support attached with this nut and you may or may not need a deep socket for this)
4. slide the alternator off the long bolt on the bottom, pull it out from the bottom and you're good. reverse order to install.
If i'm forgetting something someone please add to this.
It's pretty straightforward. but a lot easier to do if you jack it up and have a shop creeper.
It could be done from the top but it was just easier for me to put it on jack stands and get under.
I wouldn't see any reason to remove the fan. i was referring to the air intake but i dont have one so i don't know if it would even be in the way.
