If you cleaned your engine (1uz) and this happens....
Old 05-14-09, 06:58 PM
KC95SC400
KC95SC400's Avatar
Default If you cleaned your engine (1uz) and this happens....
.......runs like crap. Backfires (through both the exhaust and intake) and throws a code 13, check connector EC1.
It is located underneath the cover on the driver's side of the engine. The cover that is between the oil fill cap and the data link connector. There are three connectors, the middle one is for the front fuel injector. The one towards the rear of the car is connector EC1 and it contains all the wiring for the crackshaft and cam shaft sensors.
Mine was full of water, sprayed some contact cleaner into both sides of the connector and blew both sides out with air and all is good!
Just thought I'd share.
KC
Old 05-14-09, 07:02 PM
lilSCsteve
lilSCsteve's Avatar
where are you in NC, haven't seen that car rolling around?
Old 05-15-09, 07:26 PM
KC95SC400
KC95SC400's Avatar
Charlotte. You?
KC
Old 05-15-09, 07:53 PM
nyjdmevo
nyjdmevo's Avatar
Default helpp same thing...but sc 300 stock
This happended to me today cleaning engine wit power washer but I have a sc300 auto gonna clean this in the morning wat else can it be?? Runs like crap motor is shaking like runing on 1 cyl but not throwing a check please help somebody,, gonna let it run over night hopefully the water goes away from the heat
Old 05-16-09, 04:43 AM
Durrr
Durrr's Avatar
water in the spark plug galley.
Old 05-16-09, 01:32 PM
Sc300lexo
Sc300lexo's Avatar
i seem to be having the smae problems with mine. i switched the spark plugs about two weeks ago and it seems as it the timing is off or it is miss firing. engine shakes while in any gear and idles at a higher rpm. any ideas?
Old 05-16-09, 02:58 PM
RyanV
RyanV's Avatar
If your going to water hose your engine, wrap up sensitive electronics with saran wrap or aluminum foil.
Old 05-16-09, 04:16 PM
KC95SC400
KC95SC400's Avatar
Let me guess...... bosch plugs?
Listen guys, I started this thread to give a possible cause for trouble after washing the engine. There are plenty of other threads on the subject (search) if you don't have the same fix as I did.
KC
Old 05-16-09, 06:09 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Good info.. Thanks for the write up.
Old 05-16-09, 07:32 PM
nyjdmevo
nyjdmevo's Avatar
cleaned up the spark plug area but car still bogs here and there ???
Old 05-16-09, 08:22 PM
sc4002soar
sc4002soar's Avatar
miss fire, cud be ur ignition coils
Old 05-17-09, 05:48 PM
Da Coupe
Da Coupe's Avatar
Great info! Alot of wasted trouble shooting will be eliminated.
Old 05-17-09, 06:39 PM
RyanV
RyanV's Avatar
Wasted time and troubleshooting.
Stop washing down your engines! They put a hood w/ weather stripping on it for a reason.
Use some wd40 and a rag..you wont have these weird electrical gremlins.
The bonus to wd40 is that it displaces moisture, and leaves a nice luster and can take the grease right off your ignition wires, vacuum hoses etc.
Old 05-18-09, 07:47 AM
UZZ30-SC4
UZZ30-SC4's Avatar
+2 said this since i first heard of people having the issue. Dont be lazy, use some wd40 and some elbow grease.
Old 05-19-09, 07:21 AM
Sc300lexo
Sc300lexo's Avatar
no there ngk iridium plugs and duralast wires. everytime i give it gas it has a stall and then kicks in. relly annoy having ppl ask whats up with you trying to give me whip lash =(
Quick Reply: If you cleaned your engine (1uz) and this happens....
