550 cc injectors ??? please help
Old 05-14-09, 11:31 AM
scturbo28
scturbo28's Avatar
Default 550 cc injectors ??? please help
Hello community , i have a 1jzgte-vvti and was wondering if 550 cc fuel injectors from a 1995-1998 supra will fit my engine ? Is it just plug in play , or do i need to cut and splice into my harness to make the injectors work. thank you.
Old 05-14-09, 06:25 PM
EL MOSTRO
EL MOSTRO's Avatar
i believe is just plug and play, but i'm not 100% sure...good luck
Old 05-14-09, 08:30 PM
RyanV
RyanV's Avatar
Check Supramania.com
I've read that the 2JZGTE side feed injectors will fit the 1JZ fuel rail, but I think the 550 side feeds are low impedance(not sure).
If they are low impedance you'd need to wire in the 2JZGTE USDM fuel injector resistor box.
xspsi6
12
02-10-14 06:25 PM
scmaluco
08-15-12 02:07 PM
That-Guy
11-25-08 09:48 AM
lpolo69
09-19-06 08:38 PM
Quick Reply: 550 cc injectors ??? please help
