i have a tranny ??????? if anyone can help
I have a 93 sc400 with 165k on it and sometimes wen I put it on drive it work but sometimes it dosent un till I put it on L does anyone wat is could be?
Welcome to Club Lexus. I see this is your first post. I highly suggest you take the time to familiarize yourself with the forum and please read the FORUM RULES before posting.
Having said that, this sounds like a topic that belongs in the PERFORMANCE\MAINTENANCE section. I will go ahead and move this thread for you.
About your transmission, it sounds like it is slipping. An automatic transmission is the most neglected part of the vehicle. I've seen many slip until they eventually stop working. What I suggest you do is try and have the fluids flushed. Hopefully that takes care of your situation if it is not too late. If its got something else going on feel free to do a quick search on what might be going on.
Thanx dude but I was reading up and some ppl stay not to flash cuz it can make it wors then it already is or kill the tranny
The clutch packs in the tranny could be shot,bad fluid and there is to much metal pieces floating around inside of it. You could have a bad shift solenoid. Have it flushed and if that doesn't work i would look for a tranny to replace it with. Where in Florida do you live?
Mine does same thing. I must be the solenoids,because it starts in second or third gear.Basicaly it doesnt shift down,and starts at a higher gear. So when you put it in "L" you manualy putting it in first.I've been driving mine like this for over 8 months, have no problems.
Do a search,i think the solenoids could be replaced without removing the tranny.I'm not sure though,its been a while since i looked in to it.
AoshichanX
Automotive Care & Detailing
07-14-08 02:25 PM
DaveGS4
06-28-08 09:35 PM
