DIY, Removal of cluster, and Redo of lighting!
Old 01-21-14, 06:30 PM
  #136
scviolence
scviolence's Avatar
Originally Posted by 1JZPWRD
Good gosh that's bright. Are you the on Facebook that is offering the same service? I believe the SC Crew?
yeah thats me lol
Old 01-21-14, 07:13 PM
  #137
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
10-4 copy.....
Old 01-27-14, 03:22 PM
  #138
egaleano
egaleano's Avatar
I'm curious to know if this would work the same way with the blue scotch tape. You know, the painters tape...
I shall try this and report back....eventually.
Old 01-27-14, 04:17 PM
  #139
amckoy96
amckoy96's Avatar
Hey what part of Fl are you located at scviolence?
Old 01-27-14, 05:04 PM
  #140
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I think if you doubled it up, it might or triple it. The blue folder I had to use three pieces overlaying one another.
Old 10-05-14, 04:15 PM
  #141
BlackIRON
BlackIRON's Avatar
Best thread ever
Old 10-05-14, 04:53 PM
  #142
2jznosht
2jznosht's Avatar
Originally Posted by scviolence
yeah thats me lol
Are you the sc crew on Instagram too?
Old 02-05-15, 01:14 PM
  #143
nelson09
nelson09's Avatar
Thank you OP!
I opted to remove the tail light error bulb rather that the pin #4 trick. I replaced all of my tail light bulbs with red LED's and they didn't have the built in resistors so they threw error codes. Thank you!!! Straight forward DIY, helped me get rid of that pesky dash light. Yae for poor man's LED tails, lol. Now to shave the inners with no repercussions
edit: just noticed this was an sc thread. Thanks for helping out a 2gs owner!
Old 02-12-15, 08:09 AM
  #144
megamax
megamax's Avatar
hey there mark, long time!
Old 02-12-15, 09:29 AM
  #145
TyStephens
TyStephens's Avatar
Has anyone figured out how to change the color of the OD/Time LCD Displays?
I got the cover off and it makes it a nice Mint color but i really would like it a Red or Blue to match!
Thanks
Old 04-05-15, 06:30 PM
  #146
Sunny_Tk
Sunny_Tk's Avatar
I believe that you need to replace the whole lcd, which might be more work than gain
Old 04-29-15, 11:03 AM
  #147
dricacho
dricacho's Avatar
I didn't want to start a new thread since this one pertains to the instrument cluster lighting. I just bought my SC400 a couple of weeks ago and I noticed that the gauge lights come on and stays on while the car is running even though the light switch is not on. So when I'm driving in the day time, the instrument cluster is lit up. Is this normal or is this a sign of a bad cluster? Also, does the needle illumination come from the little bulbs in the instrument cluster or are they illuminated separately?
Thanks in advance!
Old 01-26-16, 02:25 AM
  #148
jabbajt
jabbajt's Avatar
^^^ it could be your lil eye sensor on the dash that handles the auto light function..
The needles are illuminated by a tiny bulb in the gauge/needle shaft & are incandescent.. to DIY, you'd have to put a row of surface mount diodes (microscopic damn near) on the needle itself.. the series can be powered by the same leads but will need proper resistors to handle the 12V source..
here's a brave man who hooked us up on the gravity of that undertaking..
Old 01-28-16, 05:50 AM
  #149
TaninAuto
Sponsor
TaninAuto's Avatar
Thanks in advance!
Hi, Tanin Auto Electronix here. What year is your SC400? We might be able to help you with repairs, depending on the year of the car. We aren't sure what is causing the cluster to stay lit, but as far as needles go, we can help you with that repair. The needles are illuminated separately.
We hope to be able to help you out!
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 06-21-17, 10:17 PM
  #150
GS408
GS408's Avatar
Default Odometer and time lighting
Heres the finished product with no needles! Kinda blurry, but cool!
I switched to LEDs on the 8 cluster bulbs. But how do you change the Time and Odometer Reading display to LED? I don't see any bulbs in that area.
foreste1
01-19-19 09:32 PM
RXPhil
10-31-13 01:01 PM
Devor
SC- 1st Gen (1992-2000)
01-15-11 04:26 PM
ISguy
IS - 1st Gen (2001-2005)
06-10-06 05:11 PM
Shnerez420
09-23-04 02:05 PM
Quick Reply: DIY, Removal of cluster, and Redo of lighting!
