Boosted My SC
Old 04-02-09, 08:37 PM
snomanlex
snomanlex's Avatar
Default Boosted My SC
Total install time: 6 Hours
Total Part/Misc time: 4 hours
Here are some pics of my install on my 92 SC300 5spd:
Oil Feed tap location
Old 04-02-09, 08:42 PM
snomanlex
snomanlex's Avatar
Old 04-02-09, 08:52 PM
IonFeright
IonFeright's Avatar
Looks good dude! What are you using for tuning?
Trevstuh
Trevstuh's Avatar
Nice, what kit is that. The xs power kit.
Old 04-02-09, 08:53 PM
TroySC300
TroySC300's Avatar
Nice work, what are you using for EMS?
Lets see some dyno numbers
Old 04-02-09, 09:01 PM
snomanlex
snomanlex's Avatar
Thank guys, as far as tuning I have a safc2 for now and I have to install the mk3 440s. It is the XSPower kit. My first ride couldn't even be enjoyed as the clutch start slipping. So I gotta take it easy till I get my new one. Once the new clutch is in I'll probably hit the dyno. I'd love to see what a turbo 230k 2JZ can make lol.
Old 04-02-09, 09:23 PM
5sp_jzz30
5sp_jzz30's Avatar
replace those leaking valve cover gaskets while youre at it.
check the part number on your MAF. some sc300 and gs300 came with the same MAF that is on the LS400. the LS400 MAF is a popular upgrade for the mk3 supra crowd and in general toyota people going for bigger-then-stock MAF.
my 93 sc300 has the same LS400 MAF
the part number to look for is: 22204-42011 FMZ3AYY2
also run the MAF in a blow-through setup. you wont have to worry about recirculating the blow off valve ro compensating the tune. it wont run rich at cruising or between shifts either. extend the MAF harness and put it in the fender or right before the throttle body.
looks good though.
im collecting random parts as we speak as well right now. have the mk3 7mgte injector and resistor box, greddy intercooler, oil cooler, power steering cooler, aem uego, ton of gauges. now i just need to find a CT26 and make a manifold
good luck and keep us updated. need numbers when tuned.
Old 04-02-09, 09:25 PM
al4nek
al4nek's Avatar
do you have any problems with stalling ?
Old 04-02-09, 09:31 PM
Sup2jzgte
Sup2jzgte's Avatar
NICE! You dont happen live in the Western Mass area do you? If so I was the one driving the Cobra that you were trying to race on 91 a few days ago lol.................if it was you.
Old 04-02-09, 09:36 PM
snomanlex
snomanlex's Avatar
Occasionally it does. Reminds me of my first dsms.
As far as the maf ill have to check those numbers. As far as running it in blow through I'm just going to leave it the way it is. It runs well and the that particular sensor isn't designed to be a blow through setup.
Old 04-02-09, 09:39 PM
snomanlex
snomanlex's Avatar
No sir im actually in southeast ma. im in fall river. whereabouts are you located?
Old 04-02-09, 09:42 PM
Sup2jzgte
Sup2jzgte's Avatar
AHH I see, I'm in Western Mass Chicopee (aka Ghettopee). There is a SC that looks just like yours that seems to want to race me no matter what I'm in. Whether is my SC or my brothers Cobra lol, its freaking annoying.
Old 04-02-09, 09:47 PM
DrLex
DrLex's Avatar
What you are posting is the part number of the MAF electronics (the black piece). The LS400/SC400 housing is what is bigger. So changing to LS400 eletronics does nothing for you, you need to change the actual housing to have the ability to compensate for injectors that are 25% bigger.
Snoman, nice piping, who did it?
Old 04-02-09, 10:00 PM
5sp_jzz30
5sp_jzz30's Avatar
Originally Posted by 935
What you are posting is the part number of the MAF electronics (the black piece). The LS400/SC300 housing is what is bigger. So changing to LS400 eletronics does nothing for you, you need to change the actual housing to have the ability to compensate for injectors that are 25% bigger.
the black part is the the actual MAF sensor. simply getting a bigger housing will do nothing. well it will. it will flow more air but it will not be read correctly. you need the proper sensor that has a different range than a bigger housing.
so youre trying to say that people that "upgrade" their MAF sensor are paying the extra money just for the housing. stock sensor/housing is around 40 bucks. ls400 sensor/housing is 100-150. people pay extra 100 bucks for the aluminum housing?
if thats the case i can make bigger housing and sell them to people for 75 all day.
Old 04-02-09, 10:07 PM
snomanlex
snomanlex's Avatar
not bad your only an hour or 2 away from me. as far as racing goes i work so much i barely get a chance to mess around at all.
Quick Reply: Boosted My SC
