1jz swap
Old 03-05-09, 07:59 AM
sunrisetrd
sunrisetrd's Avatar
Default 1jz swap
Hey guys, I was wondering you can give me some advice. I am in the process of doing my 1jz swap into my sc300. The engine is in, motor mounts, tranny mounts and cross member all line up and are hooked up.
The problem I'm having is that the shift linkage rod seems to be an inch long and won't line up correctly with the gears. For example, when the shifter is in park, and the linkage rod is hooked up the trans position would be in neutral.
Has this happened to anyone? because its and auto 92 sc300 and I'm putting in the soarer auto trans that it came with. Also is there anyway that the shift linkage/gear box position can be adjusted? or will I just have to cut the rod down an inch?
I appreciate any advice, thank you.
Ryan
Old 03-05-09, 01:40 PM
OneJay
OneJay's Avatar
Can you use the linkage from your SC transmission? They should be the same, but maybe for some reason they're different.
Old 03-05-09, 01:43 PM
sunrisetrd
sunrisetrd's Avatar
Yea thats the one I'm using, the engine and trans I got didn't come with a linkage rod.
Thanks
flipboi
12-20-14 07:35 AM
screaminsc
SC400 / 300 Classifieds
04-05-10 06:33 PM
SC2JZ300
06-17-09 11:06 AM
Quick Reply: 1jz swap
